  2. Logic Design
  3. Conformal Crashes for large designs
  • Subscribers 62
  • Views 16353
archive over 19 years ago
Hi
When I run conformal on a relatively large design with about some 1500 mapping points it sometimes crashes with the core dumped. What should be done in such circumstances.
Prasad
Originally posted in cdnusers.org by anssprasad
    Hi Prasad
    The most common cause is trying to synthesize the RAM's. The tool then runs out of memory at either 'read design' or 'set system mode lec'.
    The solution is to do 'add notranslate module ' before 'read design' so the guts of the RAM don't get generated.
    If your case is different then please send your log and the .lec_dump_stack file to support@cadence.com, after trying with the latest release (06.20-s200 currently).
    Chrystian
    Originally posted in cdnusers.org by croy
    Hi Chrystian,
    Thanks for your valuable inputs. My case is different from the one you mentioned. I am using the product version 6.1 only. The tool crashes when comparing and due to a single mismatching key point. I dont have access to the latest version. What can be done??
    Prasad.
    Hi Prasad
    You should have been contacted by Customer Support. Please work with them to resolve this.
    Chrystian
  • HPC-SMP1
    HPC-SMP1 over 17 years ago
    Hi Chrystian, Do you have any customers using SMP systems for running Conformal? I'd like to understand how much memory is typical for Conformal jobs and if typical users are using HPC clusters or SMPs.Thanks
