  2. Logic Design
  3. Warning during RTL Synthesis
  • Subscribers 63
  • Views 19512
Arslan
Arslan over 13 years ago
Hi, When I compile my RTL, among I get the following warning
Warning : Possible timing problems have been detected in this design. [TIM-11]
        : The design is 'counter'.
Can anyone tell me what does that mean?
  • bmiller
    bmiller over 13 years ago
     This is a very common warning, and it essentially means you may have some timing constraint issues in your design.  In order to see these constraint issues, run "report timing -lint".
     FYI, for any message code in RC, you can run "man" to see more information about the message.
    rc:/> man TIM-11
    Entry       : TIM-11
    Severity    : Warning
    Verbosity   : Message is visible at any 'information_level' above '1'.
    Description : Possible timing problems have been detected in this design.
    Help        : Use 'report timing -lint' for more information.
  • Arslan
    Hi, thanks bmiller. that was helpful. I am loading and synthesizing RTL from encounter gui, and when I type command report timing -lint, encounter does not recognize it. how to make that command run in encounter. and also if I type man TIM-11 in encounter, it says that there is no manual entry for TIM-11. How to overcome this?
  • bmiller
     I have never synthesized RTL from the Encounter GUI, so I don't know how that works.  I do know that RTL-Compiler is called "under-the-hood" for synthesis.  "report timing -lint" is an RTL-Compiler command, and the TIM-11 message comes from RTL-Compiler as well.
     If there is a way to pass commands or a script from Encounter to RTL-Compiler, you could use that to run "report timing -lint". Or, you could synthesize your RTL directly in RTL-Compiler.
  • admin
    admin over 13 years ago
