  2. Logic Design
  3. Help on CONFORMAL LEC flow using Synopsys's Design Compiler...
  • Replies 12
  • Subscribers 61
  • Views 23086
Help on CONFORMAL LEC flow using Synopsys's Design Compiler netlist
Rafeeq2129
Rafeeq2129 over 13 years ago
I'm trying to setup flow for using CONFORMAL LEC with DC netlist, and facing few problems in mapping.
--> Conformal doesn't map the RTL(async neg reset) with its counterpart  in netlist(DC).
---> Conformal Doesn't map the "SNPS_CLOCK_GATE_HIGH" latch
 **************my dofile is as follows (till it goes into lec mode)
     reset
    set log file <  >
     "sourcing project specific variables"
    set undefined cell black_box
      add notranslate filepathnames <  >
      add search path
      read library -verilog2k
       read design -noelaborate -verilog2k -nosensitive  -golden <>
         read design -noelab -systemverilog -nosensitive -golden <>
      elaborate design -golden <>
      read design  -verilog 2k -revised <>
        set flatten model -nomap -latch_transparent -latch_merge_port -seq_constant -gated_clock -seq_redundant -nodff_to_dlat_zero -verbose
 set system mode lec
please provide me the basic flow for CONFORMAL--DC netlist
regards,
rafeeq
  • grasshopper
    grasshopper over 12 years ago
     Hi Rafeeq,
     the main problem you may have is that TCL does not have a 'prepend' command but it is hard to guess without you providing any output of what message you are getting. For a list of TCL commands, please refer to
    http://www.tcl.tk/man/tcl8.5/
    hope this helps,
    gh-
  • tstark
    tstark over 12 years ago
     You should be able to use this option with write_hier_compare_dofile in TCL. It will have to be valid TC, escaped etc.
     Maybe try with something simple first and verify it works.
    There are some small sample testcases in the installation tree:
    share/cfm/lec/demo
    If it is too much of a problem try going into VPX mode (not TCL mode):
    vpxmode
    write hier_compare dofile ...
    run hier
    tclmode
    -ts
