  2. Logic Design
  3. help needed
  • Subscribers 61
  • Views 14859
help needed
archive over 18 years ago
Hello,i ma new to conformal flow.I want to know one thing.when we do RTL-RTL LEC, which one will be golden RTL and which one will be revised? Thanks in advance.
Originally posted in cdnusers.org by sujittikekar1
    The old RTL would be the golden.
    If you're new to Conformal a good place to start is to go through our online jump-start. Email conformal_workshops@cadence.com to get the details on how to sign up.
    BTW, for basic RTL-RTL the usual settings are fine if the old RTL is the golden. For more a more conservative run though use 'set x conversion E -both'. This will flag cases where don't-care spaces are not the same in both design. Otherwise don't-cares that were changed in the new RTL will not produce non-equis (which is OK for most people). See my post on 12/13/2007 for more details. The thread title was 'E Gates'.
    Chrystian
    Originally posted in cdnusers.org by croy
