  2. Logic Design
  3. RC: set_min/max_delay breaks the constrained paths
  • Subscribers 63
  • Views 5331
Sporadic Crash
Sporadic Crash over 13 years ago
I have used following command(s) to constraint path delays on FF->FF path:
set_max_delay -from $some_flops -to [get_pin inst/in_i*] 8
The path that goes through [get_pin inst/in_i*] ends in a target FF. However when after the SDC command above, when I try to generate a timing report, following message is coming from RTL Compiler:
rc:/> report timing -from [find / -inst *dat_reg*] -summary
                              Pin                                        Type      Fanout Load Slew Delay Arrival
        (fF) (ps)  (ps)   (ps)
source_inst
  dat_reg_69/CP                                                 <<<                             0             0 R
  dat_reg_69/Q                                                       qqq          3 19.9  227  +410     410 F
  g15476/D        +0     410
  g15476/Z                                                             qqq           1  7.9  327  +250     660 R
  g15435/D        +0     660
  g15435/Z                                                             qqq         1  8.9  286  +398    1058 R
  g15419/C        +0    1058
  g15419/Z                                                             qqq         1  8.6  174  +193    1251 F
  g15415/E        +0    1251
  g15415/Z                                                             qqq          1  8.9  410  +303    1554 R
  g15391/C        +0    1554
  g15391/Z                                                             qqq         3 18.3  294  +302    1856 F
source_inst/dat_o[19]
g35169/B        +0    1856
g35169/Z                                                               qqq       1  8.2  276  +358    2215 F
g34962/C        +0    2215
g34962/Z                                                               qqq          1  7.4  408  +257    2472 R
g34478/B        +0    2472
g34478/Z                                                               qqq           4 26.8  240  +379    2851 R
some_inst/data_i[19]
  g4358/E        +0    2851
  g4358/Z                                                              qqq          1  8.9  501  +300    3150 F
  g4348/C        +0    3151
  g4348/Z                                                              qqq 3 16.6  325  +337    3487 R
  xinst/B                                                  +0    3487
  xinst/Z                  qqq           1 43.4  342  +390    3877 R
  inst/in_i[9] (b)                                  +0    3877 R
Exception    : 'path_delays/zipped_path_delay_0'    8500ps
Timing slack :    4623ps
Start-point  : dat_reg_69/CP
End-point    : inst/in_i[9]
(b) : Timing paths are broken.
I have renamed instance and libcell names because company reasons.
Is there a way to disable the behaviour of RTL Compiler that breaks the path, when set_min/max_delay SDC command is given?
After the SDC command, the path from inst/in_i[9] until the FF will get unconstrained automatically, which I don't want.
  • Vinkesh
    Vinkesh over 13 years ago
    Can you try setting the below attribute? This should resolve your concern on RC breaking paths when set_max_delay is applied.--set_attribute timing_no_path_segmentation {set_max_delay} /-- Thanks
    ed!!
  • Sporadic Crash
    I have tried following combinations:
     set_attribute timing_no_path_segmentation {set_max_delay set_data_check} /
    read_sdc <file>
    ... -> still broken paths.
    Then I tried
    set_attr tim_ignore_data_check_for_non_endpoint_pins true /
    set_attr tim_ignore_data_check_for_non_endpoint_pins false /
    with the command above. Still broken paths.
    I have restarted RTL Compiler, before reading set the vars in any combination.
    Still broken paths.
    Tell me how to move.
  • sjoshi
    sjoshi over 13 years ago
     Can you please check one thing.
    You may be applying max delay at a higher level of hierarchy. Just check that there might be sequential instance below that hierarchy.
    Try putting max delay from that lowest level of hierarchy ie: reg and to the lowest level of hierarchy that is reg.
    It may solve the problem.
    thanks,
    Shobhit
