  2. Logic Design
  3. Two warnings(external_delay and CSA rejected)
  • Subscribers 62
  • Views 1403
20050710212
20050710212 over 13 years ago
There are two kind of warnings always happened during synthesis. I checked them in the user manual but I do not know how to solve them.
1. The following primary outputs have no clocked external delays.  As a result the timing paths leading to the ports have no timing constraints derived from clock aveforms. The'external_delay' command is used to create new external delays.
/designs/FIFO/ports_out/dataout[0]
/designs/FIFO/ports_out/dataout[10]
/designs/FIFO/ports_out/dataout[11]......
2.There is 1 CSA group in module 'FIFO_csa_cluster_33'... Rejected. Somtimes it is accepted. sometimes it is rejectd.                          What is CSA group?
Could you please give me some advieces to fix these problems?
Thank you very much.
  • grasshopper
    grasshopper over 13 years ago
     Hi 20050710212,
     (1) As the message specifies, the outputs have not clock reference hence no way to time paths ending at those outputs. You need to ask a set_output_delay statement in your SDC with a clock reference if you expect those paths to be timed
    (2) Carry Save Adder. Do a google search on it and you will get plenty of detailed information on adder architecture. Acceptance/Rejection depends on a variety of things, mainly your design constraints
    hope this helps,
    gh-
