  2. Logic Design
  3. RC - read_hdl
  • Subscribers 62
  • Views 6161
RC - read_hdl
Yemelya
Yemelya over 13 years ago
Hi Everyone,
When reading verilog (read_hdl -sv), first file is common variable definitions (like `define and localparam). There is no problem loading this file, however when loading the actual RTL design it cannot recognize the mentioned above variables (Error - undeclared).
If the same  variable definitions file added to RTL as `include it works, but there are too many RTL files and I have no permission to modify them.
Any idea what could the issue with loading it by (read_hdl -sv)?
Thanks a lot!
Boris
  • grasshopper
    grasshopper over 13 years ago
     Hi Yemelya,
     silly question but are you sure you are honoring Verilog scoping rules? Also, note that
     read_hdl { a.v b.v include.v }
    read_hdl c.v
    is different from
    read_hdl  { a.v b.v c.v include.v }
    since every read_hdl has its own scope hence c.v would not see the `defines of the other files and vice-versa
    Let us know what you discover.
    gh-
  • Yemelya
    Hi Grasshopper,
    Thanks a lot for your help. Actually script was reading all the files line by line with read_hdl for each one. I believed that if we define library it will resolve the scope visibility issue, but it didn't.
    It works now, after I fixed it as you advised:
    read_hdl  { include.v a.v }
    read_hdl  { include.v b.v }
    read_hdl  { include.v c.v }
    Again, thank you very much for such a quick and useful response!
    -Yemelya
