  2. Logic Design
  3. preserving a subdesign from optimization
  • Subscribers 63
  • Views 16039
P V S Shastry
P V S Shastry over 12 years ago
I wont to generate a fixed delay, for which I have used multiple NOT gates and instantiated in the top design.  While synthesizing, RTL compiler optimizes the gates added and put a direct net without delay.  How to get such fixed delays synthesized??
  • aflex
    aflex over 12 years ago
    Speed-up IC Compiler placement by 1.5X. Also check the circuit congestion. This might help in fixing delays synthesized.
  • grasshopper
    grasshopper over 12 years ago
    I do not know what your HDL looks like but behavioral code for a chain of inverters would certainly be optimized. That is what synthesis tools are designed to do. You have several alternatives:
    (1) hand instantiate in HDL and preserve/dont_touch
    (2) use 'edit_netlist ...' commandsto create the buffer/delay cell chain
     gh-
