  2. Logic Design
  3. RC compiler and ports consisting of arrays of vectors
  • Subscribers 63
  • Views 16101
MarkusK
MarkusK over 11 years ago
I've a design written in VHDL which has a port (e.g. called "test") defined as array of vectors.
During the elaboration within RC, this port is splitted up into "\test[0]", "\test[1]", ... which makes problems in the post synthesis simulation.
Is there a possibility to prevent this behaviour?
I've already tried to use "set_attr array_naming_style" and similar commands, but this does not help. Additionally I would like to pevent to use a mapper for the post synthesis simulation.
Thank you very much!
Best regards,
Markus
  • olalivier
    olalivier over 8 years ago
    Hi Markusk,
    did you find the solution to this problem ? I'm facing the exact same issue.
    Olivier
  • MarkusK
    MarkusK over 8 years ago in reply to olalivier
    Hello Olivier,
    not really, I did some work around like building a wrapper so I was able to reuse the original test case setup. Depending on the array size this can be an ugly job...
    Best regards,
    Markus
