  2. Logic Design
  3. How to handle rtl-instantiated low power cells?
  • Subscribers 62
  • Views 16690
TriStated
TriStated over 10 years ago
While using IEEE1801 standard for power intent in synthesis with RTL compiler, how does one handle the RTL - instantiated low power cells? The tool is not honoring the hand instantiated cells and is inserting low power cells again.
Thanks in advance.
  • grasshopper
    grasshopper over 10 years ago
    You will need to run the command clock_gating import for the tool to recognize them if you do not want fine-gating. Keep in mind that depending on toggle of signals, there is a purpose to multi-level gating so you may or may not want it depending on design needs and behavior
  • TriStated
    My question was more related to level shifters and isolation cells.
  • grasshopper
    Not sure what version of the tool you are using but if the cells meet the rules described in your power intent, you should not end up with additional cells inserted. There may be some discrepancy in the rule hence the tool sees a need to instantiate an additional one. You may want to check those crossings up front and make sure the rules are met
