  2. Logic Design
  3. Timing analysis in RTL Compiler
  • Subscribers 63
  • Views 16225
as90
as90 over 8 years ago
I want to look at the net arc delay for a given from_pin and to_pin on a net. Is there a command that can get me that? I tried "report net_delay_calculation" but it says that this command is not supported on physical nets.
Ankur
  • TungVo
    TungVo over 8 years ago
    Hi Ankur,
    You can set global report_timing_format {hbin arc net delay cell slew} then report_timing -from <from_pin> -to <pin_to>. The table report will show all information for you.
    Hope it can help you Slight smile
    Best,
    TungVo
  • as90
    as90 over 8 years ago in reply to TungVo
    Thank you Tung Vo. I'll try it later.
