  2. Logic Design
  3. Genus synthesis | SystemVerilog in-code attribute assig...
  • Subscribers 63
  • Views 5326
Genus synthesis | SystemVerilog in-code attribute assignment
SA202508198026
SA202508198026 over 1 year ago
I’m trying to determine whether Cadence Genus supports SystemVerilog in-code synthesis attributes (similar to how Vivado does), for example:
(* dont_touch = "true" *) logic mysignal;
My goal is to simplify my timing.sdc file.
When I try this, Genus reports:
Warning : Unused attribute [VLOGPT-506]
I’ve tested several variations without success and haven’t found much documentation or examples for Genus specifically.
- Does Genus actually support this style of attribute assignment?
- If so, what is the correct syntax?
- Can it be applied to module instances, ports, registers, or nets?
Any insights would be greatly appreciated.
Thanks in advance,
Siebe
  • MK20251020799
    MK20251020799 over 1 year ago
    Unfortunately I was told by Cadence that this syntax is not currently supported (Case for reference: 46919575)
