  2. Mixed-Signal Design
  3. Using (TI) Pspice model in Virtuoso
  • Subscribers 64
  • Views 17421
B Josime
B Josime over 13 years ago
 Hi all,
 I'm doing some simulations of a filter cicuit that uses comercial AI (ina326 from TI). I've downloaded the Pspice model available at TI and i've copied the INA326.lib content between ".SUBCKT" and ".END" to the Hspice.hsp file of the cell_view that i've created. Untill here everything's normal.
 But when i do the simulation, it doesn't work due to
"Missing or corrupt .oa file in cellview 'xxx/ina326/spectre cmos_sch schematic Hspice'. The OSS netlister can only
process cellviews that have a valid .oa file. "
Does anyone know how o help me fix this??
Regards
    There is not (yet) support for textual SPICE cellViews in Virtuoso. There is a partial implementation which was left exposed, but there's no support to netlist them in the production release.
    So you need to follow the steps in Tawna's blog.
  • B Josime
     Thank you Andrew,
    Well, it's a shame Pspice models do not work in Cadence yet. I'll try what you've suggested.
     Once Again, Thanks for the quick response.
    Well, Pspice models do work in "Cadence" ;-) (Pspice is a Cadence product). However, they don't work in Spectre (another Cadence product). Whilst we get requests now and again, using models intended for Pspice is not that common an occurrence because the focus of the simulators is somewhat different; Pspice is mostly used for board-level design, and spectre for IC design. Getting full language coverage of the Pspice language for the odd use here and there is a lot of work for not that much (overall) benefit, as you can imagine. So it's not beaten other things in the prioritization battle.
    Of course, if you're the one who happens to want to do it, it's clearly a shame!
  • B Josime
     I'm just starting to use Cadence and i did not knew those details, but yeah, i know what you mean :)
    Regards
    Bruno
