  2. Mixed-Signal Design
  3. Monto carlo simulation
  • Subscribers 64
  • Views 15346
Custom IC Desi
Custom IC Desi over 13 years ago
 i am using IC 6.1.5-64b  with foundary file of UMC-180nm. i want to use monto carlo mis match simulation to find the gain of folded cascode op amp.
in ADE-Xl after  setup the test ,i include  montocarlo model file(with extension of mc-corner.scs)   after that l loaded the saved state and i also defined the variable sigma value of 3.
after i click on the  run button it showing finished .but when i click on the plot button it shows nothing...
in cds.log file i found the following information
You must openResults() on a valid psf directory before
using this command. Make sure your openResults() worked.
Use ocnHelp('results) for more information.
    Are you actually setting up any output expressions? You won't get histograms unless you're calculating some scalar values.
    Perhaps you can upload a screenshot of your output pane in ADE XL? (Use the Options tab when replying on the forum).
