  2. Mixed-Signal Design
  3. Verilog-AMS Bias Current Modelling
  • Subscribers 64
  • Views 21079
shalem7
shalem7 over 12 years ago
Hi All,
I need to model a verilog-ams bias current model.
I had coded in this way,
I(out) <+ 1uA.
In TB i put V(out) <+I(out)/R_LAOD.
This worked fine at module level.
Does this way of model works when the module connects with a SPICE block where the current is begin sinked.
Is this the correct way to model the bias current in verilog AMS.
Please provide your inputs to code the BIAS currents properly.
Shalem
    Shalem,
    I don't think you've given enough details to go on, really. Please elaborate if you want an answer - I couldn't quite work out what you're asking (or even quite what you've implemented). Perhaps some pictures might help?
  • shalem7
    I have BIAS block and LDO Block.
    BIAS sources 1uA current and LDO sinks the same 1uA current.
    BIAS block code:
    Module BIAS_Block(en,supply,bias);
    Input en,supply;
    Inout BIAS;
    Electrical supply,bias;
    Logic en;
    Analog begin
    If(en==1’b1) begin
    I(bias) <+ 1e-6;
    End
    else begin
    I(bias) <+ 0.0;
    End
    Endmodule
    LDO block code:
    Module LDO_Block(ldo_en,bias,supply,ldo_out);
    Input ldo_en,supply;
    Inout ldo_out,bias;
    Electrical supply,ldo_out,bias;
    Logic ldo_en;
    Real R_load=5K;
    Analog begin
    V(bias) <+ I(bias)*R_load; //If i do not limit the bias pin voltage,then V(bias) is going to much higher values which is not desirable.
    If(ldo_en==1’b1 && I(bias)>0.8e-6) begin
    V(ldo_out) <+ 1.8;
    End
    else begin
    V(ldo_out) <+ 0.0;
    End
    End
    Endmodule
    Now I want to replace the LDO block with SPICE instead of v-ams.
    In this case does the MOS in LDO block sinking the 1uA bias current limits the voltage of bias pin.
    I see no reason why this should be an issue.
  • shalem7
    Thanks Andrew,
    I haven't tried to replace it with SPICE because we are at initial phase of developing the VAMS Models.
    Once i try it and will post my findings for any issues and concerns.
    Shalem
