  2. Mixed-Signal Design
  3. Vhdl-ams beginner
  • Subscribers 65
  • Views 17703
Vhdl-ams beginner
sebgimi
sebgimi over 12 years ago
 I'm really new in vhdl-ams, I write my firsts codes in this langage and I have some issues to understand some basics of this extension.
My tutor want me to describe an analogic comparator and test it with a ramp waveform. A schema of this circuit is in attachment.
I don't know how to connect the both entity like on the schema. What kind of type, class, mode I have to use for each port of each entity.
And above all how to simulate the hole component (ramp + comparator) in a testbench...
 Maybe my questions are surprising but I never study vhdl-ams in college so I have a large lack of informations that internet can't provide me...
Sebastien
    Behavioral Modeling with VHDL-AMS (same course available in other regions). Also for books:
    The System Designer's Guide to VHDL-AMS: Analog, Mixed-Signal, and Mixed-Technology Modeling (Systems on Silicon... by Peter J. Ashenden, Gregory D. Peterson and Darrell A. Teegarden (Sep 18, 2002)
    and:
    VHDL-AMS : Applications et enjeux industriels (French Edition) by Herve
    or (in English):
    VHDL-AMS by Yannick Herve (Mar 1, 2006)
    There are also tutorials on AMS Designer in the documentation, which have more of a tool focus.
  • AlbertoLopez
    AlbertoLopez over 6 years ago
    Hello Sebastien,
    To create the ideal comparator in vhdl-ams is quite simple and straightforward.
    • The code should be something like this (depending if you want to have threshold or not).
    You can find the full code, test bench and simulation results on the source: ideal comparator
    entity comparator is
    GENERIC(
    Vthres : REAL := 0.1 --threshold
    PORT(
    TERMINAL Vin : ELECTRICAL;
    TERMINAL Vref : ELECTRICAL;
    result : out std_logic
    end entity comparator;
    ARCHITECTURE vhdlams of comparator IS
    QUANTITY Volt ACROSS Vin TO Vref;
    BEGIN
    --result <= '1' when (Vin > Vref) else '0'; --without threshold
    result <= '1' when Volt'above(Vthres) else '0'; --With threshold
    END vhdlams;
