  2. Mixed-Signal Design
  3. VPI within analog section
  • Subscribers 65
  • Views 18541
Fabian007
Fabian007 over 12 years ago
I'm trying to implement the VPIs in analog section.
My final goal is to implement a dynamic filling Table Lookup in a circuit simulator. Therfore I want to use the C-/C+ Structure as a Database and i need to call the vpi-function at everey call of the model.
Within an inital section, it is no problem to call the c-Funktion.
Within an analog section I get the error message below.
I'm not really sure if it is possible to call a VPI-routine within an analog section. The only example I found was in the VAMS-LRM: www.accellera.org/.../VAMS-LRM-2-4.pdf chapter: "12.22. Examples" page: 339(PDF), 324(Document). But I do not know where to find "vpiutils.h" and the example doesent work.
Do you know how to connect the VPI to a analog section?
Do you have other  examples?
 Do you haveother ideas?
Thank you very much
My AMS-Code is:
// resis.vams
`include "disciplines.vams"
module resist (p,n);
    parameter real r=30;
    inout p,n;
    electrical p,n;
    analog begin
        $hello;
        V(p,n) <+ r*I(p,n);
    end
endmodule
// vsrc.vams
module vsrc (p,n);
    parameter real dc=10;
    inout p,n;
    electrical p,n;
    analog
        V(p,n)<+dc;
endmodule
// top.vams
`include "resist.vams"
`include "vsrc.vams"
module top;
    electrical p, gnd;
    ground gnd;
    resist #(.r(7)) R1(p,gnd);
    vsrc #(.dc(1)) V1(p,gnd);
endmodule
My C-File is:
//hello_vpi.c
#include <stdio.h>
#include "vpi_ams.h"
#include "vpi_user.h"
#include "vpi_user_cds.h"
void hello()
    printf("HELLO\n");
void register_hello()
    s_vpi_systf_data data;
    data.type = vpiSysTask;
    data.tfname ="$hello";
    data.calltf=hello;
    data.compiletf=0;
    data.sizetf=0;
    data.user_data=0;
    vpi_register_systf(&data);
My simulation control file is:
//scf.scs
myopt options rawfmt=psfbin
myinfo info what=oppoint where=rawfile
mytran tran stop=4u infoname=myinfo infotimes=[1u 2u 3u]
My commands are:
cd /home_ma/hos/Cadence/NC_Verilog/vpi_simple_circuit_01
gcc hello_vpi.c -fPIC -shared -o hello_vpi.so
ncverilog scf.scs top.vams +access+r -loadvpi ./hello_vpi.so:register_hello
My Error Message is:
irun(64): 13.10-s005: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
file: top.vams
    module worklib.resist:vams
        errors: 0, warnings: 0
    module worklib.vsrc:vams
    module worklib.top:vams
$CDSROOT = /eisoft/cadence/2013-2014/lnx86/INCISIVE_13.1
$TESTDIR = /home_ma/hos/Cadence/NC_Verilog/vpi_simple_circuit_01
TOOL:    ncsc(64)    13.10-s005
ncsc cc parameters:
    $CDSROOT/tools/cdsgcc/gcc/4.4/bin/gcc
    -I$CDSROOT/tools/include
    -I$CDSROOT/tools/inca/include-DNCSC
    -fPIC
    -c
    -x c  -Wall
ncsc: compiling $TESTDIR/hello_vpi.c
$TESTDIR/hello_vpi.c: In function 'register_hello':
$TESTDIR/hello_vpi.c:16: warning: assignment from incompatible pointer type
building library run.so
        Caching library 'worklib' ....... Done
    Elaborating the design hierarchy:
    Top level design units:
        top
    Discipline resolution Pass...
    Building instance overlay tables: .................... Done
    Building instance specific data structures.
    Loading native compiled code:     .................... Done
    Design hierarchy summary:
               Instances  Unique
        Modules:       3       3
        Interconnect:  2       -
    Writing initial simulation snapshot: worklib.top:vams
Loading snapshot worklib.top:vams .................... Done
    Starting analog simulation engine...
AMSD: Using spectre solver.
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 12.1.1.080.isr11 64bit -- 25 Jul 2013
Copyright (C) 1989-2013 Cadence Design Systems, Inc. All rights reserved
        worldwide. Cadence, Virtuoso and Spectre are registered trademarks of
        Cadence Design Systems, Inc. All others are the property of their
        respective holders.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
        Security, Inc.
User: hos   Host:   HostID:  PID:
Memory  available: 1.0687 GB  physical: 4.0176 GB
CPU Type: Intel(R) Core(TM)2 CPU          6700  @ 2.66GHz
Analog Kernel using -ANALOGCONTROL  scf.scs.
Reading file:
        /home_ma/hos/Cadence/NC_Verilog/vpi_simple_circuit_01/scf.scs
        $hello;
ncsim: *E,SYFATAL (/home_ma/hos/Cadence/NC_Verilog/vpi_simple_circuit_01/resist.vams,8|7): `$hello' - Unsupported system task/function.
Error found by spectre during circuit read-in.
    ERROR (VACOMP-1816): Exiting AHDL compilation.
    ERROR (SPECTRE-356): AMS Analog Elaboration has exited with error.
        Simulation will terminate.
spectre terminated prematurely due to fatal error.
ncsim: *E,RNAERR: The simulator terminated with an analog initialization error.
  • JoshOp
    JoshOp over 10 years ago
    Hi Fabian, have you had any success with this issue? Or another way of implementing lookup tables that worked?
  • Fabian007
    Fabian007 over 10 years ago
    Hi Xiaoxi,
    no im very sorry but i haven't had any success. I tried some other  simple ways but they were not fast enough. Do you have an idea for me?
    There is only very limited support for Analog parts in VPI in INCISIVE - enough to detect whether something is in the analog domain but not much else. There are enhancement CCRs to extend this, but it's not planned currently. You might want to create a case with customer support to request this, but even then I don't see it being done soon (as it's been this way for many years).
    If you are just after a table lookup, there is $table_model already in Verilog-AMS. Of course, this may not meet your needs - but just mentioning it in case you weren't aware of it.
  • JoshOp
    Thanks for the response Andrew, I see. I looked into the $table_model built into Verilog-AMS and can make use of it in my initial use cases, but want to be able to implement my own interpolations, match parameters to frequency, matrix calculations, and move data in and out of other simulation schemes.  I'm currently reading through the Verilog PLI handbook, and have seen articles discussing Verilog-AMS + VPI ( http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=5775124  ) , so have gone down this path.  I also recently saw some of your replies about "CMI", but thought I'd pursue VPI if that is feasible since I have it's documents for beginning use. Do you have any thoughts on this direction? Thanks for your feedback and help, really appreciate it.
    Best,
    X.W.
    It should be possible to use VPI on the digital side - so you could (for example) implement a system function - e.g. $mytable - which is called on the digital side and deals with real numbers. Many years ago I wrote a library of math functions for Verilog XL which worked this way. So maybe that approach might suit you.
    The difficulty on the analog side is not that the standard doesn't support it, it's just that it hasn't been implemented in AMS Designer (there hasn't been a great deal of demand for it, so it's a matter of focussing development effort where it's most needed).
