  2. Mixed-Signal Design
  3. cadence gpdk045 callback issue
  • Subscribers 64
  • Views 15309
somebody1234
somebody1234 over 11 years ago
I faced some issue when I try to change the width and length of the transistors, e.g. nmos1v or pmos1v, in the gpdk045.
It gave me error messages "undefined function - gpdk045_mosDisplay( 'dtemp )" and "undefined function - gpdk_mosEditable" ,etc.
Could anyone kindly advise?
Thanks.
    This suggests that something is missing from your gpdk045 library installation. In the gpdk045 library itself, I see these files:
    UNIX> cd gpdk045
    UNIX> ls *.il* *.cxt
    gpdk045.cxt           gpdk045_PDKRegistrations.il  libInitCktPro.il      pdkUtils.cxt
    gpdk04564bit.cxt      gpdk045_customFilter.il      libInitCustomExit.il  pdkUtils64bit.cxt
    gpdk045_ModelMgmt.il  libInit.il                   loadCxt.ile
    The libInit.il for the library should load the loadCxt.ile which will load the context files (the .cxt) - either the 64-bit or 32-bit version depending upon the executable. The functions mentioned above should be in the cxt files.
