  2. Mixed-Signal Design
  3. Urgent!! Help needed on Mixed Signal simulation using AMS...
  • Subscribers 63
  • Views 16036
Urgent!! Help needed on Mixed Signal simulation using AMS Simulator
Ankit01
Ankit01 over 11 years ago
Hi
I am facing problem in simulating mixed signal circuit. In this design  used an CMOS inverter (analog) whose output is given to a D flip flop (verilog model). When I am simulating design by using AMS simulator I am getting errors. I am attaching netlist of my simple design. I have looked into previous post  dealing with similar errors but I was NOT able to solve my problem.
Fullscreen Netlist.txt Download
// PLEASE DO NOT EDIT OR COMPILE THIS FILE.
// IT IS MEANT FOR VIEWING PURPOSE ONLY.
// All files for configuration: (INVERTER_FF Test_ckt config)
// AMS netlist generated by the OSS based AMS netlister
// IC subversion:  IC6.1.5.500.17
// IUS version: 12.20-s038
// Copyright(C) 2005-2009, Cadence Design Systems, Inc
// User: ankit_soc Pid: 23986
// Design library name: INVERTER_FF
// Design cell name: Test_ckt
// Design view name: config
// Solver: Spectre
`include "disciplines.vams"
`include "userDisciplines.vams"
// Library - INVERTER_FF, Cell - ams_inv_ff, View - schematic
// LAST TIME SAVED: Apr 15 00:08:13 2015
// NETLIST TIME: Apr 15 01:00:11 2015
`timescale 1ns / 1ns
(* cds_ams_schematic *)
module ams_inv_ff (OUT, VDD, VSS, CLOCK, RESET, Vin);
output  OUT;
inout  VDD, VSS;
input  CLOCK, RESET, Vin;
p_18_mm #(.w(1u), .l(500n), .nf(1), .mis_flag(1), .ad(4.9e-13),
    .as(4.9e-13), .pd(2.98u), .ps(2.98u), .m("(1)*(1)"),
    .mf("(1)*(1)"))
(* integer passed_mfactor = "m"; *)
M0 (net16, Vin, VDD, VDD);
n_18_mm #(.w(2u), .l(500n), .nf(1), .mis_flag(1), .ad(9.8e-13),
    .as(9.8e-13), .pd(4.98u), .ps(4.98u), .m("(1)*(1)"),
    .mf("(1)*(1)"))
M1 (net16, Vin, VSS, VSS);
d_ff I0 ( .q(OUT), .clk(CLOCK), .data(net16), .reset(RESET));
endmodule
// Library - INVERTER_FF, Cell - Test_ckt, View - schematic
// LAST TIME SAVED: Apr 15 00:56:34 2015
module Test_ckt ();
ams_inv_ff I0 ( .VSS(cds_globals.\gnd! ), .VDD(VDD), .OUT(OUT),
    .CLOCK(CLOCK), .RESET(RESET), .Vin(DATA));
vsource #(.type("pulse"), .val0(1.8), .val1(0), .period(1m),
    .width(100u)) V2 (RESET, cds_globals.\gnd! );
vsource #(.type("pulse"), .val0(0), .val1(1.8), .period(4u),
    .width(2.5u)) V1 (DATA, cds_globals.\gnd! );
vsource #(.type("pulse"), .val0(0), .val1(1.8), .period(1u),
    .rise(10.00n), .fall(10.00n), .width(500.0n)) V0 (CLOCK,
vsource #(.dc(1.8), .type("dc")) V3 (VDD, cds_globals.\gnd! );
endmodule
// Verilog-AMS cds_globals module for top-level cell:
//    INVERTER_FF/Test_ckt.
// Generated by ADE.
// Cadence Design Systems, Inc.
// This is an autoGenerated file, any changes done to this file may get lost.
module cds_globals;
// Global Signals
   electrical \gnd! ;
   ground \gnd! ;
// Design Variables
endmodule
// This is the Cadence AMS Designer(R) analog simulation control file.
// It specifies the options and analyses for the Spectre analog solver.
simulator lang=spectre
simulatorOptions options temp=27 tnom=27 scale=1.0 scalem=1.0 reltol=1e-3 \
vabstol=1e-6 iabstol=1e-12 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 pivrel=1e-3 checklimitdest=psf
dcOpInfo info what=oppoint where=rawfile writedc="dcOp"
tran tran stop=40u errpreset=moderate save=none write="spectre.ic" \
writefinal="spectre.fc" annotate=status maxiters=5
# This is the NC-SIM(R) probe command file
# used in the AMS-ADE integration.
# Database settings
if { [info exists ::env(AMS_RESULTS_DIR) ] } { set AMS_RESULTS_DIR $env(AMS_RESULTS_DIR)} else {set AMS_RESULTS_DIR "../psf"}
database -open ams_database -into ${AMS_RESULTS_DIR} -default
# Probe settings
    If this is urgent, you should go to customer support. These forums are not official support and are only answered in everyone's spare time.
    In this case, those messages should be benign warnings - I don't see from the above why it is failing, and since I don't have the model files, it's hard to know what the real error is.
