  2. Mixed-Signal Design
  3. Verilog-AMS : Incorrect wreal net value of E2R connect ...
  • Subscribers 64
  • Views 17321
Verilog-AMS : Incorrect wreal net value of E2R connect module
SimhanAnalog
SimhanAnalog over 10 years ago
I have a mixed signal circuit and during simulation the simulator will automatically add connect modules. Since the circuit is small I have saved all nets(including connect modules). The functioning of the circuit is as expected indicating that all connect modules are functioning correctly.
But one strange observation is that when I go inside any E2R connect module(using viva or simvision) and plot the input and output, the input is correct but the output is zero for all time. But outside the connect module the blocks that the connect module drives has the correct signal. This is observed in all E2R connect modules irrespective of the connect module parameters. Since there are several built in connect modules(rules) to choose from, we tried juggling but still the same observation. Then we went ahead and wrote a simplified connect module and tried for a simple circuit. But still the same result. I thing this is a bug since other connect modules work correctly(L2E,E2L,R2E).
Here is the connect module that we wrote for your reference in case there is an issue with the module(but as I said this issue is observed with built in connect modules as well).
connectmodule e2r(A,Y);
  input A;
  electrical A;
  output Y;
  wreal Y;
  logic Y;
  parameter real vdelta = 50u;
  parameter real vtol = vdelta/4;
  parameter real ttol = 5p;
  real A_r = 0.0;
  always @(absdelta(V(A), vdelta, ttol, vtol))
    A_r = V(A);
  assign Y = A_r;
endmodule
    Not really enough information to work on here. I suggest you go to customer support.
