  2. Mixed-Signal Design
  3. bulk-source or bulk-drain junction diode forward biased...
  • Subscribers 64
  • Views 4327
bulk-source or bulk-drain junction diode forward biased :-(
Charanraj Mohan
Charanraj Mohan over 9 years ago
Hey,
 I am translating few schematics from 0.35um to 130nm. I found the difficulty in encountering warnings like 'the bulk-source or the bulk-drain junction diode is missing and it is forward biased'. How to encounter these critical warning where the simulations go abnormal. This happens only during a small time of the transient simulation. I don't need to use a bulk connection, rather how to tackle these kinda warnings ? I surfed a lot and couldn't find a right way or approach to tackle these in the schematic level. I am grateful to know if any such exists.
Thanks in advance.
    There's a section in the troubleshooting chapter of the Spectre User Guide that talks about this message. It may or may not help you...
  • Charanraj Mohan
    Thanks Andrew.
    I went through it.
     And later found that it occurs mainly because of  high speed switching time of my test input signal in the schematic. For example, if i use 1ns of rise time or fall time, these warnings occur. When i use 100ns these warnings disappear. I would like to know if I can kick these warnings by some tuning setup in the ADE like when I use small abstol and small gmin, I get more accurate. I am saying this for an example.
    I want that the simulator should handle well the fast input pulse/switching too and give me no warnings. Is there any tuning parameters in the ADE ?
    Thanks in advance :-)
    There are lots of tuning parameters in spectre, but without knowing the specifics of your issue, I don't think I can offer much advice. Perhaps you can contact customer support so that an Application Engineer can look at your setup and what's going on?
