  2. Mixed-Signal Design
  3. Cannot start ncsim when launching ams simulation
  • Subscribers 64
  • Views 19027
abcng111
abcng111 over 8 years ago
Hi all,
I got a problem on mixed signal simulation using MMSIM 15.2 and INCISIV 15
When I have configured the MMSIM and INCISIV package, I start to run a tutorial called "vfs_amsflow"
I could successfully finish the ncvlog and ncelab phase, but error is exist when entering ncsim
Analog Kernel using -ANALOGCONTROL
/tmp//simulation/aeq_ac_sim/ams/config_ams/netlist/amsControlSpectre.scs.
Reading file:
Error found by spectre during circuit read-in.
ERROR (VACOMP-2353):
"/home/xxx/ams_tutorial/vfs_amsflow/VFS_AMS_PHY180/adc_IREF_ext/verilogams/verilog.vams":
GCC version mismatch found. The GCC installation is either corrupted or
has been modified. To solve the issue, either use the GCC version that
came packaged with the release, or reinstall the release.
ncsim: *F,INTERR: INTERNAL EXCEPTION
Observed simulation time : 0 FS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
TOOL: ncsim(64) 15.20-s027
HOSTNAME: xxxx
OPERATING SYSTEM: Linux 3.10.0-693.11.6.el7.x86_64 #1 SMP Thu Jan 4 01:06:37 UTC 2018 x86_64
MESSAGE: dlib_openPakLib() - got bad parameter
csi-ncsim - CSI: Cadence Support Investigation, sending details to /tmp//simulation/aeq_ac_sim/ams/config_ams/netlist/ncsim_14915.err
csi-ncsim - CSI: investigation complete, send /tmp//simulation/aeq_ac_sim/ams/config_ams/netlist/ncsim_14915.err to Cadence Support
ncsim: Memory Usage - 36.4M program + 414.2M data = 450.6M total (455.8M Peak)
ncsim: CPU Usage - 0.1s system + 0.3s user = 0.4s total (16.3s, 2.3% cpu)
Failed to simulate ("VFS_AMS_PHY180_sims" "aeq_ac_sim" "config_ams").
Does anyone know how to solve it?
James
    Andrew Beckett over 8 years ago +1
    Hi James, I can't find any reports of the same problem (at least nothing recent). I'm not sure it's related to the GCC version mismatch (that may be a diversion) - may be related to a permission problem…
    Hi James,
    I can't find any reports of the same problem (at least nothing recent). I'm not sure it's related to the GCC version mismatch (that may be a diversion) - may be related to a permission problem in the TMP dir (check the cds.lib - does it have any ASSIGN TMP type definitions and if so are any of these pointing to dirs/files that aren't writable)?
    The best next steps would be to:
    1. Update to the latest Hotfix of INCISIVE152 in case it's been fixed
    2. Contact customer support as it suggested in the messages above.
  • abcng111
    abcng111 over 8 years ago in reply to Andrew Beckett
    Thank you for your reply. I guess it is the GCC version that is incompatible to INCISIVE15.2, But I have used the checkSysConf command to check the system configuration, GCC could pass. I am using Centos 7.4, but I do not think Linux distribution is critical.
    However, I do not know which GCC version should be used and how to install it.
    James
    Andrew Beckett over 8 years ago in reply to abcng111
    James,
    I'm not sure this is necessarily anything to do with the GCC warning - that may be a coincidental warning.
    CentOS is not a supported platform for Cadence software, although RHEL7 is for INCISIVE152 so that ought to be OK in practice (no guarantees).
    We'll need to investigate further - hence the suggestion to try the latest hotfix and if not go to customer support.
  • abcng111
    I have contacted the Customer Support today. As I am a graduate student, but my university does not sign contact with Cadence directly. The Cadence is provided by another institution. So they would not give any support.
    You will need to get the organisation that provides you the software to raise a support request on your behalf. If in Europe that would often be Europractice - but elsewhere in the world normally there is a nominated contact person who can log support requests.
  • abcng111
    After contacting the institution that provided Cadence package to us, they said that the INCISIVE version is needed to be upgraded to perform the mixed mode simulation. After the INCISIVE upgraded to 15.20.039, the mixed mode simulation could run now
    Thank you for any advice
    James
