  2. Mixed-Signal Design
  3. Verilog-A to access wire bus of DUT
  • Subscribers 65
  • Views 20095
slim15
slim15 over 8 years ago
I am trying to create a verilog-A model to extract bus of nets of my DUT in a similar manner to the component deepprobe from analogLib in a Spectre transient simulation. These buses are at least 20-bit wide and it will be error-prone if I were to add them manually. I created a verilog-A block where I instantiate on the same level as my DUT and the code for the verilog-A is included below. If I try to use Cadence's verilogA editor,for the code below, I get the error "(TE-4309): extract failed for cellview "sandbox simCell_NetnameAccess veriloga". If I comment out the line "V(NetOfInterest01) <+ 1.0*V(NetNameInt);", extraction went smooth and transient simulation yield
  From testbench level, string name is IDUT.UCOMP_TOP.INT_CLK<0>
  From verilog-A level, string name is IDUT.UCOMP_TOP.INT_CLK<0>
is there something I need to do to process string to capture the triangular brackets?
thanks!
========== verilog-A code ==========
`include "constants.h"
`include "discipline.h"
module simCell_NetnameAccess(NetOfInterest01,NetOfInterest02);
  output NetOfInterest01,NetOfInterest02;
  electrical NetOfInterest01,NetOfInterest02;
  //parameter definition
  parameter string NetName = "DUT.XYZ";
  string NetNameInt = "IDUT.UCOMP_TOP.INT_CLK<0>";
  analog begin
    @(initial_step) begin
      $strobe("From testbench level, string name is %s\n", NetName);
      $strobe("From verilog-A level, string name is %s\n", NetNameInt);
    end // END of [ @(initial_step) ]
    V(NetOfInterest02) <+ 1.0*V(NetName);
  end // END of [ analog ]
endmodule
  • Dimitra Papazoglou
    Dimitra Papazoglou over 8 years ago
     I don't think that the extract fails because of the bus syntax. I think the failure happens because OOMR nodes can only be constant or parameterized. From the Verilog-A Language reference, it looks like you can not use string variable.
    Cadence Verilog-A Language Reference -- 9 - Out-Of-Module Reference
    So you will need to replace ' string NetNameInt = "IDUT.UCOMP_TOP.INT_CLK<0>"; ' with ' parameter string NetNameInt = "IDUT.UCOMP_TOP.INT_CLK<0>"; ' - you can also use localparam. Or you can use the literal string directly in the branch contribution statement, ' V(NetOfInterest01) <+ 1.0*V("IDUT.UCOMP_TOP.INT_CLK<0>"); '.
    Dimitra
