  2. Mixed-Signal Design
  3. How to make schematic CDF parameter become integer in AMS...
  • Subscribers 67
  • Views 18970
How to make schematic CDF parameter become integer in AMS?
drdanmc
drdanmc over 8 years ago
I have a block I often use in spectre simulations that takes a parameter and generates a bunch of voltages to provide configuration or trim bits.  The block has a CDF string parameter, "CODE", of type string with "parse as CEL" and "parse as number" both checked.  Then in my schematic for the block I have expressions like the following for bit 1:
((pPar("CODE")>>1) & 1)? 1 : 0
for the gain on analogLib/vcvs or dc value on an analogLib/vdc.  This works fine in spectre which interprets pPar("CODE") as an integer.
I can also use
((int(pPar("CODE"))>>1) & 1)? 1 : 0
to be more explicit that it is an integer which is being shifted and bit-wise anded and spectre is still happy.
The problem lies when I use AMS as the simulator.  Now I get errors like:
file: ./netlist.vams
vcvs #(.gain(((CODE>>1)&1)?1:0)) E1 (SRC[1], VSS, VDD, VSS);
ncvlog: *E,NOSHRL (./netlist.vams,29|22): Illegal type real shift operand (left operand) [4.1.1][4.1.12(IEEE)].
ncvlog: *E,BDRLLO (./netlist.vams,29|34): Illegal type real left operand to & (bit-wise AND) operator [4.1(IEEE)].
and if I try adding in that int() in the schematic, the netlister converts to real2int() and I get:
vcvs #(.gain(((real2int(CODE)>>1)&1)?1:0)) E1 (SRC[1], VSS, VDD, VSS);
vcvs #(.gain(((real2int(trimCode)>>1)&1)?1:0)) E1 (SRC[1], VSS, VDD, VSS);
I can't change the parameter type to integer in the CDF because this precludes me from using a design variable to specify the CODE value.
So.... is there an expression I can use in a schematic that will work correctly for both spectre and AMS?  I it comes down to it I can create an AMS view for the cell but I'd hoped to not add additional views if not needed.
    Hi Dan,
    This only happens for me if you eventually set the parameter to be a design variable. In other words, the netlister does not set the type of the parameter passed into the Verilog-AMS module, and I only get the error if the passed parameter ultimately gets passed a real number. So say that the instance of the block as you've described has the CDF parameter CODE set to MYCODE then the AMS netlister netlists MYCODE in the cds_globals module as:
    // Design Variables
      dynamicparam real MYCODE = 43;
    It's this that then causes the problem. Luckily there's an option on Simulation->Options->AMS Simulator which allows you to define variables to be netlisted as integer:
    This resolves the problem altogether.
    I have a component bussetp (described in this article: Creating a component that allows setting a value on a bus in an analog simulation) which works in a similar fashion. I probably should update that article to mention the need for top level design variables to be netlisted as integer...
  • drdanmc
    drdanmc over 8 years ago in reply to Andrew Beckett
    Yes, indeed, I was ultimately using a design variable.  Thanks for the tip.  I'd missed that option in the netlister.  It works now.
