  2. Mixed-Signal Design
  3. DC offset
  • Subscribers 65
  • Views 21433
DC offset
Charanraj Mohan
Charanraj Mohan over 8 years ago
Hello all,
  I am doing a simulation to determine the DC offset of a two-stage PMOS-based differential opamp. Say, for instance I am using some technique to calibrate the DC offset of the opamp or even assume that I simply observe the DC transfer characteristics curve & determine the DC offset by keeping the reference voltage to VDD/2. I want to know the contribution of that DC offset in terms of % of every MOSFET. DC offset voltage mainly arises due to the device mismatch, differential or current mirror pair's un-matching & other factors. Say, the DC offset of the opamp is 50 mV & I want to determine each MOSFET's contribution or at least a MOSFET-pair's contribution to it. Is it possible in Viruoso Visualization & Analysis tool of CADENCE ?
 Thanks in advance :)
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago
    I suggest that you take a look at https://community.cadence.com/cadence_blogs_8/b/cic/posts/the-art-of-analog-design-part-4-mismatch-analysis and https://community.cadence.com/cadence_blogs_8/b/cic/posts/the-art-of-analog-design-part-5-response-to-frank-s-question for a start.
