  2. Mixed-Signal Design
  3. define different but related parameters in array of stimuli...
  • Subscribers 64
  • Views 16023
define different but related parameters in array of stimuli to ADE
CSCNalu
CSCNalu over 7 years ago
Hi
I'm trying to simulate a rather large part of my design that expects 128 inputs that are all delayed from each other (sequenced in order) that basically turn on switches.  Is there an easy way to define this in the schematic cell with an analogLib part?  Basically I need a pulse of a fixed length but I want the delay to be cascaded.
I know how to make an array of 128 vsource stimuli but I'd rather not make 128 different sources that go to 128 different nets that have 128 (1:1:127) * delay as the start up.
Chris
    Hi Chris,
    I'd do this with a Verilog-A model:
    // VerilogA for mylib, delayedSrcs, veriloga
    `include "constants.vams"
    `include "disciplines.vams"
    `define NUMBITS 128
    module delayedSrcs(src);
    output [`NUMBITS-1:0] src;
    electrical [`NUMBITS-1:0] src;
    parameter real td=10n;      // initial delay
    parameter real trf=1n;      // rise and fall time
    parameter real offset=50n;  // offset delay between bits
    parameter real val0=0.0;    // low voltage
    parameter real val1=1.2;    // high voltage
    parameter real width=100n;  // width of pulse. Set to 0 if you don't want it to go low again
    parameter real period=0.0;  // period of pulse once started. 0 means one shot (not periodic)
    integer srcVal;
    genvar bit;
    analog begin
        // if period is 0, then the pulse is a one-shot. Otherwise it's
        // periodic
        @(timer(td,period)) begin
            srcVal=1;
        end
        // this allows the pulse to return to 0. If you don't want that
        // set the width parameter to (can be set on the instance)
        @(timer(td+trf+width,period)) begin
            if (width>0) begin
                srcVal=0;
            end
        end
        // Generate all the delayed sources
        for(bit=0; bit<`NUMBITS; bit=bit+1) begin
            V(src[bit]) <+ transition(srcVal*(val1-val0)+val0,offset*bit,trf);
        end
    end
    endmodule
    If you create a Verilog-A view inside Virtuoso (I called the cell "delayedSrcs"), it will then ask you to create a symbol. When you instantiate it, you can use the "Tool Filter" to see the parameters - you might in your case want to set width to 0 on the instance if you don't want the pulses to return to 0 after going high.
    Another possibility would have been to create a schematic PCell, but I think the VerilogA approach is simpler in this case.
  • CSCNalu
    CSCNalu over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks - that's incredibly helpful.  Didn't even know I could do anything like this; this should be fun.
    Chris
