  2. Mixed-Signal Design
  3. Issues with .cdsinit loading
  • Subscribers 64
  • Views 17047
growingmind
growingmind over 7 years ago
I am running Cadence Virtuoso / Design Framework IC6.1.7-64b.78 on Linux, B Shell.
I get the following error upon start in the CIW window/command line:
Loading ./.cdsinit init file from the site init file.
*Error* load : can't access file - "./.cdsinit_61"
Now the .cdsinit where I run Cadence from does not load.
But when I type load ("/path/to/filename") of my .cdsinit in the CIW window/command line it loads properly.
What is wrong here and how do I fix this ?
Thank you.
    I'm guessing the file is either not in the working directory, you have the filename wrong, or the permissions are such that it can't be opened.
