  2. Mixed-Signal Design
  3. How to convert analog value to digital in calculator
  • Subscribers 64
  • Views 21006
pyohayo
pyohayo over 7 years ago
The expression like this:
value(VT("aaa") 1.0e-6) > 1.0
doesn't work in calculator because return value is either t either nil.
Does exist a function that converts nil to 0 and t to 1 ?
Thanks.
    Try:
    if(value(VT("aaa") 1.0e-6) > 1.0 then 1 else 0)
  • pyohayo
    pyohayo over 7 years ago in reply to Andrew Beckett
    Unfortunately doesn't work:
    - Warning -
    <Calculator>
    Evaluation error(ERROR : ("greaterp" 12 t nil ("*Error* greaterp: can't handle (drwave:261157656 > 1.0)"))). Expression: if(value(VT("/I8/osb<7>") 6.5e-05) > 1.0 then 1 else 0)*128
    Andrew Beckett over 7 years ago in reply to pyohayo
    It's getting a waveform (I'm guessing you're doing this on ADE XL/Explorer/Assembler results, or doing a parametric sweep), so you need something more complex. Probably using abApplyToWave found in this post would help. Probably better to use this newer version that can be more easily registered with the calculator.
    You could then do something like:
    abApplyToWave(lambda((val) if(val>1.0 then 1 else 0)) value(VT("aaa") 1.0e-6))
    Note, I didn't test this, but I think that would be OK. Anyway, here's the updated code:
    /* abApplyToWave.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 24, 2011
    Modified   Dec 20, 2017
    By         A.D.Beckett
    Function to apply a unary function to every element
    in a waveform. For example:
    abApplyToWave('round waveform)
    This can be registered with the calculator using the fx
    button in the Function Panel in IC617 and later. Includes
    the GUI builder template
    SCCS Info: @(#) abApplyToWave.il 12/20/17.14:21:36 1.5
    *                    (abApplyToWave func arg)                     *
    *  And finally, the function that does the work. You give it the  *
    *  name of a unary function (takes one argument) which works on   *
    * numbers, and then this is applied to all members of a waveform. *
    *                      Handles families too.                      *
    (defun abApplyToWave (func arg)
      ; convert string function name to symbol
      (when (stringp func)
        (setq func (concat func)))
      (cond
        ((numberp arg) (funcall func arg))
        ((drIsDataVector arg) (vecMap 'abApplyToWave func arg))
        ((drIsWaveform arg)
         ; Create new waveform, but transfer units if not set on
         ; new waveform already. This ensures plotting on the same y-axis
         (let (new yVec)
           (setq new (wfMap 'abApplyToWave func arg))
           (setq yVec (drGetWaveformYVec new))
           (unless (getq yVec units)
             (putpropq yVec (getq (drGetWaveformYVec arg) units) units)
           new
        ((famIsFamily arg) (famMap 'abApplyToWave func arg))
        (t
          (error "abApplyToWave: can't apply %L to %L\n"
                 func arg)
    ;;;;;;;;;;;;;;;;;;;;;;;;;; GUI builder information ;;;;;;;;;;;;;;;;;;;;;;;;;;;
    ocnmRegGUIBuilder(
     '(nil
      function abApplyToWave
      name abApplyToWave
      description "Apply func to waveform"
      category ("Custom Functions")
      analysis (nil
          general (nil
            args (func arg )
              signals (nil
                    arg (nil
                          prompt "Signal"
                          tooltip "Signal"
              params(nil
                     func (nil
                           prompt "Function Name"
                           tooltip "Name of function"
                           guiRowHint 0
                           type string
                           default "round"
                           required t
            inputrange t
      outputs(result)
