  2. Mixed-Signal Design
  3. Is there an eval command in Verilog-a?
  • Subscribers 64
  • Views 16628
LDIL
LDIL over 6 years ago
Hello all.
Is there a command in Verilog-a, which accepts a string, and evaluates it as code, like in SKILL/TCL?
I don't think so, but wanted to make sure.
Thanks.
    Andrew Beckett over 6 years ago +1
    No. I'm not sure how this would be useful - Verilog-A is not a general purpose programming language, so doing things like this at run time would be a bit odd... Andrew
  • LDIL
    LDIL over 6 years ago in reply to Andrew Beckett
    True. But odd does equate useless... It is intended for debug pruposes, not for normal run, where performance is paramount. Compiled languages are harder to get something like this done, and hardware languages in particular, usually won't need that. The LRM showed nothing of the kind, but it is better to ask than to double check.
    Thanks, and enjoy the weekend before I interrupted it.
    Andrew Beckett over 6 years ago in reply to LDIL
    This isn't really because Verilog-A is compiled (because that's an implementation choice for performance), but more that it's a hardware description language. Changing the description of the hardware (as this would then be doing) would be hard anyway, especially as this might involve a change in the matrix formulation that needs to be solved.
    Anyway, no problem for interrupting my weekend!
