  2. Mixed-Signal Design
  3. Best practices for Verilog-a modelling time variant res...
  • Subscribers 65
  • Views 18888
Best practices for Verilog-a modelling time variant resistance
LDIL
LDIL over 6 years ago
Hello all.
I am simulating a design with time variant resistor, which values can be in [oHM] from thousands to even millions. I now set it as a simple real.
What is the best practice for assigning values/ setups for it, in order to have no convergence issues or runtime issues?
I mean, usually the voltage is no more than 5V, and the currents are less than 1e-2.
Thanks.
    ShawnLogan over 6 years ago
    Dear LDIL,
    I'm not sure how many values your time variant resistor has - nor the physical mechanism you are trying to model (other than aging perhaps?). If the number of time breakpoints is not too many to code, you could model it however as a piecewise linear source if you combine your piecewise linear source with a controlled source. This would avoid the use of  a verilogA  model if you are concerned about issues relating to convergence with a verilogA model. I can't state this is the "best practice", but it might be something to consider.
    Shawn
    Andrew Beckett over 6 years ago in reply to ShawnLogan
    Without more information it's really hard to answer this, as Shawn has pointed out. If the resistance has a voltage dependency, you need to ensure that the voltage dependency is stable and also you are modelling reasonably across a very wide range of voltages (not just the voltages you typically see in the circuit). I've seen issues where people (including large foundries) have modelled nonlinear resistors using a quadratic equation and have forgotten that there are two roots - one was physical and the other was non-physical - it ended up where during the route to convergence a large voltage appeared across the resistor (which wouldn't happen in real life), which caused the resistor to become negative, which caused it to get stuck in this non-physical region.
    The other thing you normally want to take care about is ensuring that the resistor value changes smoothly rather than discontinuously.
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago
    General advice for behavioral modeling can be found in chapter 3 "AMS Behavioral Modeling" of the "Mixed-Signal Methodology Guide". This chapter was written by Ron Vogelsong from Cadence and can be downloaded (in four parts) from https://www.eetimes.com/book-excerpt-mixed-signal-methodology-guide-part-4/#. Especially the section "Modeling Best Practices Considerations" contains lots of valuable advice. Another excellent resource is the article "Best Practices for Compact Modeling in Verilog-A" by Colin McAndrew et al. which is in Open Access and can be downloaded from https://ieeexplore.ieee.org/document/7154394.
