  2. Mixed-Signal Design
  3. Need help on identifying issue with VerilogAMS issue
  • Subscribers 64
  • Views 15700
Quantum7
Quantum7 over 6 years ago
Setup a testbench with config view and a verilogams block which will drive test signals towards my analog stuff.
right now I am making a very simple cell in verilogams, its basically a unit which drives 10ns clock.
inside the testbench i defined a module which takes that clock and converts it to continuous signal for my analog circuit.
Below is a code:
//Verilog-AMS HDL for "libtest", "ams_test1" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
module signal_d2a (in, out);
reg in;
electrical out;
parameter real trise=2n, tfall=2n;
parameter real digOutHigh = 5.0, digOutLow = 0.0;
integer logicState;
analog begin
if (in == 1'b1)
logicState = digOutHigh;
else
logicState = digOutLow;
V(out) <+ transition(logicState, 0, trise, tfall);
end
endmodule
module ams_test1 (
out );
output out;
wire outsig;
reg clko;
signal_d2a out1(
.in(clko),
.out(outsig) );
initial
begin
clko=0;
end
always
#5 clko = !clko;
assign out = outsig;
endmodule
I am getting following error, and not understanding what exactly is wrong:
xmelab: *E,CUVMUR (/proj/ams_test1/verilogams/verilog.vams,36|14): instance 'ams_testbench1.I0@ams_test1<module>.out1' of design unit 'signal_d2a' is unresolved in 'libtest.ams_test1:verilogams'.
Any idea what exactly i am doing wrong? again, its basically a "clock" generator, and a function to transition it from purely discrete to continuous signal.
    ShawnLogan over 6 years ago
    Dear Quantum7,
    It sounds as if you are using the Hierarchy Editor and the error is occurring during the elaboration phase. Have you seen the following that may address your issue? There are a lot of details you have not included about your setup and simulation environment, and hence it is difficult for me to provide any more specific guidance. Others who are far more expert than I on the use of veriloga modules in the application you describe may better recognize your error message. However, this thought came to mind and I thought it worth pointing out.
    support.cadence.com/.../ArticleAttachmentPortal
    Shawn
