  2. Mixed-Signal Design
  3. Error "hiCreateCyclicField" and warning "TECH-2000178" in...
  • Subscribers 64
  • Views 3499
Error "hiCreateCyclicField" and warning "TECH-2000178" in Virtuoso IC6.1.7-64b.500.4
CarlosMP
CarlosMP over 5 years ago
I'm getting this following message when I try to create a wire in a schematic L .
* Field is "color" *
*Error* hiCreateCyclicField: value must be contained within the list of choices.
I tried this solution "tracev(_schgColorIcons color)" from https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/28316/error-on-creating-wire-in-virtuoso, but it didn't work.
Also, I can't select hierarchical blocks which I created and I'm getting several warnings like these:
*WARNING* (TECH-2000178): A Layer Number conflict has been detected in the technology hierarchy.
 It is caused by the following list of layers: tsmcN65/PO (#17); cdsDefTechLib/VIA8 (#17).
*WARNING* Technology database conflict: There are layer numbers which conflict in the incremental techlibs
*WARNING* (TECH-2000050): Unable to set references on tech because conflicts would result. In tech tsmcN65
I tried this solution from https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/31589/technology-hierarchy-error-that-causes-objects-can-t-be-selected and the results are:
techIsDBUPerUUSet(techGetTechFile(ddGetObj("cdsDefTechLib")) "maskLayout")
techIsDBUPerUUSet(techGetTechFile(ddGetObj("tsmcN65")) "maskLayout")
techGetDBUPerUU(techGetTechFile(ddGetObj("cdsDefTechLib")) "maskLayout")
techGetDBUPerUU(techGetTechFile(ddGetObj("tsmcN65")) "maskLayout")
techGetViewTypeUnits(techGetTechFile(ddGetObj("cdsDefTechLib")))
techGetViewTypeUnits(techGetTechFile(ddGetObj("tsmcN65")))
nil
t
1000.0
1000.0
nil
(("maskLayout" "micron" 1000)
    ("schematic" "inch" 160)
    ("schematicSymbol" "inch" 160)
    ("netlist" "inch" 160)
If anyone could help me, I would appreciate it.
Carlos.
    Carlos,
    This sounds rather as if either you have a local cdsDefTechLib or it has been edited in your software installation and has been broken. There should be no layer called "VIA8" in cdsDefTechLib nor should it use layer number 17. It's possible the schematic color issue might be related too - not entirely sure, but it seems possible.
    So first check what ddGetObj("cdsDefTechLib")~>readPath returns. It should be something like this:
    "/export/home/apps/IC618_isr/tools/dfII/etc/cdsDefTechLib"
    prependInstallPath("etc/cdsDefTechLib")
    "/export/home/apps/IC618_isr/tools.lnx86/dfII/etc/cdsDefTechLib"
    (essentially similar paths other than the .lnx86 maybe in one and not the other).
    If it is somewhere else, check your cds.lib to see if it references another path and remove that entry. If it is the one in the installation, my guess that it had write permission and you or somebody has overwritten the technology database. If this is the case, you may want to re-install your software (or maybe copy the cdsDefTechLib from another installation if you don't want to do that).
    You'd need to restart virtuoso having done this.
  • CarlosMP
    CarlosMP over 5 years ago in reply to Andrew Beckett
    thanks for your quick response. I'll check it under the supervision of my mentor.
    Carlos.
