  2. Mixed-Signal Design
  3. xmsim: *F,RNAERR: The simulator terminated with an analog...
  • Subscribers 64
  • Views 5983
xmsim: *F,RNAERR: The simulator terminated with an analog initialization error.
Pedro P
Pedro P over 5 years ago
I have a AMS simulation that simulates fine with APS++, when I select to run the same simulation with spectreX I get:
The simulators does not give more hints to what have happened.
How can i debug what is the issue ?
    Most likely you'll need to go to customer support for this - but the first thing I'd ask is are you using the latest XCELIUM (2009) and SPECTRE (20.1) - ideally a recent hotfix of each?
    You didn't mention which versions are being used.
  • Pedro P
    Pedro P over 5 years ago in reply to Andrew Beckett
    Hi Andrew the versions I'm using are :Spectre 20.10.126 , xcelium 20.09.008 , Cadence 06.18.160
    I lunch the simulation via assembler and have set the simulator to be ams, it has part verilogams part schematic and systemverylog.
    simulating with aps++ using flex to use the latest spectre it runs just fine, when I enable spectrex , just can't make it to run I get the error i've posted and some complain about
    spectre terminated prematurely due to fatal error.
    Should I have no issues with this version?
    Andrew Beckett over 5 years ago in reply to Pedro P
    Pedro - I think it will need more detailed investigation. This should work, so there must be something about the specific situation that we'll need to look into.
    I'll get one of the local team to contact you (I'm a bit busy today).
  • Pedro P
    I made it to work after a few re-netlisting , all fine now
