  2. Mixed-Signal Design
  3. RLC series circuit
  • Subscribers 64
  • Views 13820
RLC series circuit
vshnkmr
vshnkmr over 4 years ago
Can somebody tell me how to plot  both the magnitude and phase behavior of the loop current and the voltage across resistor, capacitor and inductor over a  frequency range of 1mHz to 1MHz .
I have made the schematic , but dont know how to plot. can somebody help me with it giving detailed step. I am new to this , please help me.
Kind Regards
R.Vishnu Kumar
    Which tool and software version are you using?
  • vshnkmr
    vshnkmr over 4 years ago in reply to Andrew Beckett
    I am using cadence virtuoso.
  • vshnkmr
    vshnkmr over 4 years ago in reply to vshnkmr
    Virtuoso 6.1.8
  • vshnkmr
    Virtuoso 6.1.8
    ShawnLogan over 4 years ago in reply to vshnkmr
    Dear vshnkmr,
    vshnkmr said:
    Virtuoso 6.1.8
    Since that version of Virtuoso supports ADE Assembler and Explorer, I will assume you are using one of those ADE simulator tools. Hence, I have assembled a set of instructions in the Portable Document Formatted file at URL:
    https://ent.box.com/s/4tf0zyzv09vxfkcdv4ajdquw0ss9j1i7
    (Link will expire at the end of 2021)
     I also have attached a compressed (".zip") file. If you unzip this file, the comma-separated variable files of both test bench variables and test bench outputs are included that you may import into your maestro Explorer view IF the net names are the same as your Virtuoso test bench. If note, you may first edit each file to change the net names to those in your Virtuoso schematic and then import them. I included instructions as to how to import the outputs file in the Portable Document Formatted file. I hope the instructions are sufficiently clear to provide you with the insight you need.
    Shawn
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/92/outputs_5F00_variables_5F00_in_5F00_rlc_5F00_test_5F00_bench_5F00_sml_5F00_110621.zip
