  2. Mixed-Signal Design
  3. Allowed amount of input wreal data type
  • Subscribers 67
  • Views 13932
marzi
marzi over 4 years ago
hi everyone
I'm a newbie at using Verilog-ams and also I want to write a module for flash ADC for a specific application. I need to confine my voltages reference so I wrote this Verilog-ams code for testing input allowed value at wreal data type.
I arranged a test bench for my code that the inputs are a sine voltage with 6 V amplitude and a clock signal for Sequential circuit in verilog code.
out put is a 8 bit signal , consider that is 8-bit-adc.
as you can see at the first figure below the first change happened at 0.1 volt but it shouldn't haapen and then I was expected at the second figure , it change at 1 volt on input in but it didn't happen.
at the end I don't know what I done here incorrect.
regards
    Andrew Beckett over 4 years ago in reply to marzi +1
    marzi said: I really appreciate your reply. I was thinking that I'm talking to myself because no one said anything:) Hi Marzi, One thing to realise is that this forum is responded to by the community…
  • marzi
    I wanted to use the source code option in this forum but it didn't work:)))) sorry
    I write it again below
    `include "constants.vams"
    `include "disciplines.vams"
    module wreal_test (in,out,clk );
        input in,clk;
        output reg [0:7]  out;
        wreal in;
        integer i ;
        real sample;
    //    assign out=0;
            always @(posedge clk)
            begin
                sample = in;
                if (0<sample<1)
                    out=8'b00000001;
                else if (1<sample<2)
                    out = 8'b00000010;
                else if (2<sample<3)
                    out = 8'b00000011;
                else if (3<in<4)
                    out = 8'b00000100;
                else if (4<in<5)
                    out = 8'b00000101;
                else
                    out = 8'b00000000;
            end
    endmodule
  • marzi
    dozen people saw this question but no one hadn't paid attention that we cant write "if(0<in<1)" .
    yeah I know that's a shitty mistake for programmers but I didn't get any error so I thought that it was not a problem.
    ShawnLogan over 4 years ago in reply to marzi
    Dear marzi,
    I did see your initial post, but your question was not clear to me and hence I did not respond. I have since read your two additional posts and still do not fully understand what you are asking and do not understand your comment:
    "... that we cant write "if(0<in<1).
    yeah I know that's a shitty mistake for programmers but I didn't get any error so I thought that it was not a problem."
    Nevertheless, I am assuming perhaps you are experiencing some type of error when using your code for an 8 bit ADC.  You only indicate the code "didn't work" so I do not understand what type of error you are observing. Is it a compiling error? Is the conversion not what you expect? What are the inputs and outputs connected to?
    Since I don't know these answers, all I can do is provide a sample code for an 8 bit ADC that I have used for years in both DC and transient analyses with the hope you can modify it for your use. The code is shown below.
    Shawn
    Fullscreen 8bit_ad_tran_compatible.va.txt Download
    // VerilogA for simple transient compatible eightbit_ad,
    // sml 8/10/2020
    module eightbit_ad(VOUT, VDD, VIN, VSS);
    output [7:0] VOUT;
    electrical [7:0] VOUT;
    input VDD;
    electrical VDD;
    input VIN;
    electrical VIN;
    input VSS;
    electrical VSS;
    integer vin_integer;
    parameter real rise_fall_time = 50e-12;
    integer vout[7:0];
       analog begin
       vin_integer = V(VIN,VSS);
       if (vin_integer%256<128) V(VOUT[7],VSS)<+V(VSS);
          else V(VOUT[7],VSS)<+V(VDD,VSS);
       V(VOUT[7],VSS)<+ transition(V(VDD)*vout[7],rise_fall_time,rise_fall_time);
       if (vin_integer%128<64) V(VOUT[6],VSS)<+V(VSS);
          else V(VOUT[6],VSS)<+V(VDD,VSS);
       V(VOUT[6],VSS)<+ transition(V(VDD)*vout[6],rise_fall_time,rise_fall_time);
       if (vin_integer%64<32) V(VOUT[5],VSS)<+V(VSS);
          else V(VOUT[5],VSS)<+V(VDD,VSS);
       V(VOUT[5],VSS)<+ transition(V(VDD)*vout[5],rise_fall_time,rise_fall_time);
       if (vin_integer%32<16) V(VOUT[4],VSS)<+V(VSS);
          else V(VOUT[4],VSS)<+V(VDD,VSS);
       V(VOUT[4],VSS)<+ transition(V(VDD)*vout[4],rise_fall_time,rise_fall_time);
       if (vin_integer%16<8) V(VOUT[3],VSS)<+V(VSS);
          else V(VOUT[3],VSS)<+V(VDD,VSS);
       V(VOUT[3],VSS)<+ transition(V(VDD)*vout[3],rise_fall_time,rise_fall_time);
       if (vin_integer%8<4) V(VOUT[2],VSS)<+V(VSS);
          else V(VOUT[2],VSS)<+V(VDD,VSS);
       V(VOUT[2],VSS)<+ transition(V(VDD)*vout[2],rise_fall_time,rise_fall_time);
       if (vin_integer%4<2) vout[1]=0;
          else vout[1]=1;
       V(VOUT[1],VSS)<+ transition(V(VDD)*vout[1],rise_fall_time,rise_fall_time);
       if (vin_integer%2<1) vout[0]=0;
          else vout[0]=1;
       V(VOUT[0],VSS)<+ transition(V(VDD)*vout[0],rise_fall_time,rise_fall_time);
       end
    endmodule
  • marzi
    marzi over 4 years ago in reply to ShawnLogan
    hi Shawn
    as you said "
    "I had written about my inputs  "
    "Also I said I'm getting a result that is not my expectation and I didn't say anything about the error because I didn't have any errors :)
    In my second reply which I explain my mistake, every programmer knows that this conditional for if (0<in<2) is not correct because it should be like this (in>0 & in<2), and it's an obvious mistake. I was struggling with the concept of wreal type(because I'm a newbie at verilog-ams) and I didn't pay attention to this obvious mistake.
    In the end, as I said I really appreciate your reply and your time.
    sincerely
    marzi
    Hi Marzi,
    One thing to realise is that this forum is responded to by the community - including those of us that happen to work for Cadence. It's not part of my role at Cadence to answer here - but I do what I can to help. I was just extraordinarily busy this week and hence didn't even have a chance to look at your question, let alone answer it. I'm sure that's the same for many others.
    If you need urgent help, you should contact customer support. We do what we can to help in these forums though!
  • marzi
    marzi over 4 years ago in reply to Andrew Beckett
    hi Andrew
    I've seen every time that you answered lots of questions on this forum, I know you are kind to everyone.
    yeah, I've got that you are busy, I was just joking :)
    thanks for your effort for all of us on this forum.
     lots of times you've been my hero about errors on my way;)
