  2. Mixed-Signal Design
  3. requesting to help adding model library in spice netlis...
  • Subscribers 66
  • Views 12265
requesting to help adding model library in spice netlist
sateesh20
sateesh20 over 4 years ago
Hii all
i am using ELDO simulator to simulate spice netlist for id_vd polt of MOSFET. I am showing spice netlist below-
.lib key=mos5v0 mos_bsim3_5V0.lib mos5v0_TT
M1 D G 0 0 MEDEL=EN5V0_BS3JU  W=7e-6 L=1e-6
Vg G 0 x
.param x=1
.step param x 1 5 0.5
Vd D 0 1
.option post=2
********************DC analysis****************
.dc Vd 0 5 0.5
.plot id(M1)
.end
Error: M1  EN5V0_BS3JU model not yet to define.
i am not understand why eldo showing above defined error after adding library, while I am already mentioned  model for M1 in the library .
please chek is the way of defining library is correct and please help me if any another way of defining the library.
Please help me
sateesh
    I'm assuming you've not realised that Eldo isn't a Cadence product, but from Siemens EDA (Mentor). Asking about it on a Cadence forum isn't likely to be the most effective way of getting an answer - I suggest you contact Siemens EDA support or ask on one of their forums.
  • sateesh20
    Hii all
    Vg G 0 x
    .param x=1
    Vd D 0 1
    .option post=2
    .dc Vd 0 5 0.5
    .plot id(M1)
    .end
    Please help me
    sateesh
