  2. Mixed-Signal Design
  3. Failed to import verilog files
  • Subscribers 67
  • Views 15380
Yongqi Hu
Yongqi Hu over 4 years ago
I want to import the verilog files into cadence, it doesnot work ,
ERROR: Failed to run the xmvolog analyzer because the analyzer binary could not be located. Either the analyzer binary does not exist in the shell search path or you do not have the required permission on the file. set the correct shell search path and update the file permissions before running the command again
However, I have already installed the XCELIUN2109 successfully, I don't know why it failed. Hope someone can give some advice on how to solve this problem.
Really appreciate that!
Yongqi Hu
  • Yongqi Hu
    Hope someone can help me
    Andrew Beckett over 4 years ago in reply to Yongqi Hu
    If this was urgent, you should contact customer support. This forum is aided by members of the community (including people like me who happen to work for Cadence - we do this in our spare time).
    I'm assuming you are trying to import the Verilog files into Virtuoso? There is no tool called "cadence" (Cadence is the name of the company, not the name of any tool). You didn't mention the tool or version of that tool that you are importing into.
    However, the most likely problem is that you haven't set up your UNIX path. You might have installed XCELIUN2109 (sic) but have you added <XCELIUM2109instDir>/tools/bin to your UNIX $PATH? At the UNIX terminal, what do you get if you type "xmvlog -version" ?
    Can you also show what you get with "virtuoso -W" ?
  • Yongqi Hu
    Yongqi Hu over 4 years ago in reply to Andrew Beckett
    I am sorry, I am trying to import the verilog files into virtuoso.
    xmvlog -version : xmvlog 21.09-s012
    virtuoso -W: IC6.1.8-64b.500.28
    And I have already add  <XCELIUM2109instDir>/tools/bin to your UNIX $PATH.
    I am not sure whether the version of XCELIUM lead to this problem.
    Thanks for your reply
    Yongqi
  • Yongqi Hu
    Yongqi
    It might be this: 'Unable to run the ncvlog analyzer' or 'Failed to run the xmvlog analyzer' error when trying to perform VerilogIn to import verilog netlist
    I certainly can reproduce the error if I've got <ICinstDir>/bin rather than <ICinstDir>/dfII/bin in my path.
  • Yongqi Hu
    Thanks a lot, your method is very useful, the verilog files can be imported into virtuoso successfully now .
    Yongqi
