  2. Mixed-Signal Design
  3. Virtuoso visualization and analysis wiondow does not update...
  • Subscribers 68
  • Views 10653
Virtuoso visualization and analysis wiondow does not update in tran analysis
NewScreenName
NewScreenName over 3 years ago
Dear all,
I am running tran simulations in ADE Assembler on ICADVM20.1 and normally when plotting the waveforms even before the end of the simulation I should be able to see them up to the time point where the tran sim has been calculated, however I see that it is not exactly the case in a testbench and I cannot figure out why.
What happens is that it will show updated waveforms only at some time points. For example, the simulation lasts 300ns and I observe that there are some time instants, say t1=6ns, t2=117ns, t3=276 ns, such that if tran analysis has not reached t2 yet, then the waveforms will be plotted only until t1.
However if tran analysis has reached the time point  t suche that t2<t<t3 then waveforms will be plotted until t2.
Same applies for  when tran analysis reached point t>t3, then the waveforms will be plotted unitl t3.
There might be other "plottable" time points which I did not observe.
Simply tran analysis, errpreset liberal.
What can this be due to and how to fix it? I would need to see in any time the most updated waveforms for the simulation being run.
PS: if the simulation is stopped, then the waveforms for the whole calculated time span.
Thank you and best regards
    ShawnLogan over 3 years ago +1
    Dear NewScreenName, NewScreenName said: I am running tran simulations in ADE Assembler on ICADVM20.1 and normally when plotting the waveforms even before the end of the simulation I should be able…
    Dear NewScreenName,
    If I understand your question correctly and your database format is psfxl, I believe you may want to reduce the time interval between write flushes to the psfxl data base. This can be controlled by the environmental variables CDS_PSFXL_FLUSH_INTERVAL, CDS_PSFXL_INIT_FLUSH_INTERVAL, and CDS_PSFXL_MAX_FLUSH_INTERVAL. The following two articles may help you set appropriate values. The second URL is specific for the version of the tools you are using (ICADVM20.1).
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSj9EAE&pageName=ArticleContent
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=explorer.xml&title=Virtuoso%20ADE%20Explorer%20User%20Guide%20--%20Specifying%20Output%20Data%20to%20be%20Saved%20or%20Plotted%20-%20Environment%20Variables%20for%20PSFXL%20Output%20Format&hash=pgfId-1025205&c_version=ICADVM20.1&path=Explorer/ExplorerICADVM20.1/chap4.html#pgfId-1025205
    I hope this helps eliminate issue NewScreenName!
    Shawn
  • NewScreenName
    NewScreenName over 3 years ago in reply to ShawnLogan
    Thank you very much!
    ShawnLogan over 3 years ago in reply to NewScreenName
    Dear NewScreenName,
    Of course! I am just happy to read it helped out a little - and I thank you for letting us know!
    Shawn
