  2. Mixed-Signal Design
  3. RMS value of transient sub-interval
  • Subscribers 67
  • Views 9396
Daniel Stracke
Daniel Stracke over 3 years ago
is there an easy way to determine the RMS value of a transient waveform for a specific time-interval
in Cadence virtuoso?
The rms function itself does not provide such parameters and I could not find a way to define the transient
waveform parameter itself within the time-interval.
Best regards
Daniel
    Andrew Beckett over 3 years ago +1
    Daniel, Use the clip function to limit a waveform to a particular x range and then use the rms function on the result of the clip function. Regards, Andrew
    Daniel,
  • Daniel Stracke
    Daniel Stracke over 3 years ago in reply to Andrew Beckett
    Hey Andrew,
    thanks for the quick response. Works perfectly Slight smile
    Best regards,
    Daniel
