  2. Mixed-Signal Design
  3. SystemVerilog: Assign a array to a bus
  • Subscribers 67
  • Views 12160
HoWei
HoWei over 3 years ago
I want to assign an array of sigals to an output bus, as in the example below.
The order of assignements is dependent on the control input:
module mytest(
input logic control,
input real inA,
input real inB,
output real myOut[5:0]
assign myOut[5:0] = ( control == 1'b1) ? {inA, inA, inA, inB, inB) : {inB, inA, inB, inA, inB} ;
But this does not work, since it does not accept the array {} for the assignement.
How can I do this assignement properly ?
  • tpylant
    tpylant over 3 years ago
    You are trying to do concatenation when what you want to do is array assignment. Also, your array was too big for the assignment. Here is the code that works:
    module mytest(
      input real inA,
      input real inB,
      output real myOut[4:0]
      assign myOut[4:0] = ( control == 1'b1) ? '{inA, inA, inA, inB, inB} : '{inB, inA, inB, inA, inB} ;
    endmodule
    Tim
  • HoWei
    HoWei over 3 years ago in reply to tpylant
    Hi Tim,
    yes, the example was buggy as the dimensions of the arrays did not match. Thanks for the working example.
    Is there a way to write the array in a short form - assume I do have a 64-bit array and want to assign all "inA" or "inB".
    Can I do something like this:
    assign myOut [63:0] = ( control == 1'b1) ? [63:0] inA : [63:0] inB;
    I want to avoid to type 64-time the "inA" / "inB"  in brackets, like '{inA, inA, inA ...}.
  • tpylant
    tpylant over 3 years ago in reply to HoWei
    You should look up "SystemVerilog array assignment" to confirm, but I think the following will work:
    assign myOut[64] = (control==1'b1) ? '{ 64 {inA} } : '{ 64 {inB} };
    Tim
