  2. Mixed-Signal Design
  3. Using PLL+Pnoise to simulate PLL, failed to converge
  • Replies 11
  • Subscribers 68
  • Views 8020
Yongqi Hu
Yongqi Hu over 3 years ago
I am simulating the PLL (accomplished by Verilog A) using PLL+Pnoise, but it failed to converge, and I tried a lot of methods to make it converge, unfortunately, it all failed.
So I want to know if there are any methods to make the PLL converge.
I really hope someone can give me some advice.
Thanks a lot.
    ShawnLogan over 3 years ago
    Dear Yongqi Hu,
    Unfortunately, I do not know anywhere near enough information to provide any concrete suggestions (such as basic PLL architecture, divider(s), verilog-A modules, simulator (spectre, +aps, ++aps, spectre X?), version and simulator settings.
    I am not sure if you saw the following recent Forum post concerning the use of pnoise for a PLL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/55593/observing-pll-phase-noise-with-hbnoise/1388552#1388552
    There may be some suggestions and documentation you may find relevant. There are many other discussions on the use of pnoise for PLL contained within the Forum.
    Shawn
  • Yongqi Hu
    Yongqi Hu over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    I am sorry I forgot providing more specific information.
    The PLL architecture is a simple Type I PLL, including XOR module, LPF module, VCO module(sinwave function), comparator module(convert sinwave to squre wave), divider(dividing ratio is 2), all these modules are verilog-A modules except for LPF module.
    Simulator is ++ aps, the version is  20.1.0.534.isr17.
    And I saw the Forum post you provided, the suggestions that provided were using trans simulation to simulate the phase noise of PLL, but the simulation time was too long, and I still want to use PSS+Pnoise to simulate pll, so could you please give some advice about it?
    Thanks for your reply
    Yongqi
    Andrew Beckett over 3 years ago in reply to Yongqi Hu
    Yongqi,
    There's still not really enough information to give you much advice on this - seeing the Spectre log file might help, but the best thing would be to contact customer support and sharing the test case so that an application engineer can take a look. In particular, it will be important to check that the Verilog-A models are truly not dependent upon hidden states (in other words, you've not just added the attributes to the model to suppress the hidden state check). There's specific steps you need to do to write a divider model that is hidden-state free - can you at least share that model here?
  • Yongqi Hu
    Yongqi Hu over 3 years ago in reply to Andrew Beckett
    Sure, the following code is my divider verilog-A code. Actually, I change the divider veriloga-A model to a D-filp flop based divider, the PLL still didnot converge.
    module divider(vin, vout);
    input vin;
    output vout;
    electrical vin, vout;
    integer cnt;
    integer vout_val;
    analog begin
    @(initial_step) begin
    cnt = 0 ;
    end
    @( cross( V(vin)-0.5, +1 ) ) begin
    cnt = cnt+1 ;
    if(cnt == 8)begin
    cnt = 0;
    end
    end
    end
    analog begin
    if(cnt == 0 |cnt == 1 |cnt == 2 |cnt == 3)begin
    vout_val = 1;
    end else begin
    vout_val = 0;
    end
    end
    analog begin
    V( vout ) <+ transition( vout_val, 0, 10f ) ;
    end
    endmodule
    Yongqi
    Yongqi,
    This doesn't make sense. You said your divider was a divide by 2 - that model is a divide by 8. Secondly, there's no chance of that "failing to converge" in PSS. It simply won't run in PSS, because it contains hidden states. Spectre will report:
    Error found by spectre during periodic steady state analysis `pss'.
        ERROR (SPCRTRF-15177): PSS analysis doesn't support behavioral module
            components with hidden states found in component 'divider'. Skipped.
            forum171.va, declared in line 9: Hidden state variable: cnt
            Rewrite the module to remove the hidden state or if you confirm this
            hidden state will not affect the simulation result, you can ignore
            those hidden states in RF analysis by adding attribute
            'ignore_hidden_state' before the module declaration. For example, (*
            ignore_hidden_state *) module moduleA.
    The suggested workaround of using (* ignore_hidden_state *) is not a solution here because the hidden state will affect the simulation result.
    You're not going to get much help if in addition to not providing enough information you are not describing either the data you're using or the error you're seeing.
  • Yongqi Hu
    Andrew,
    I am sorry, I revised the verilog-A code to divider by-2 and the previous code is the unrevised version(which is divide by 8 ), and the following is the code
    input vin;
    output vout;
    integer cnt;
    integer vout_val;
    analog begin
    cnt = 0 ;
    end
    cnt = cnt+1 ;
    if(cnt == 2)begin
    cnt = 0;
    end
    end
    end
    analog begin
    if(cnt == 0 )begin
    vout_val = 1;
    end else begin
    vout_val = 0;
    end
    end
    analog begin
    end
    endmodule
    Yongqi
    Yongqi,
    It still has a hidden state though, so will fail in exactly the same way - i.e. with an error, not a convergence problem.
  • Yongqi Hu
    Andrew,
    But I didn't fail in the same way as you,  I'm either having issues with not converging, or the PSS keeps running, running and running.
    And I tried to replace the divider to a transistor-based divider, it still failed to converge.
    Yongqi
    Have you added that attribute to your model? You didn't include the entire model because the `include "disciplines.vams" was missing - so maybe there was something above. Also, are you using Spectre?
  • Yongqi Hu
    Yes, I have added that attribute to my model. And I am using spectre. The following picture is the error.
