  2. Mixed-Signal Design
  3. Using PLL+Pnoise to simulate PLL, failed to converge
  • Replies 11
  • Subscribers 68
  • Views 8021
Yongqi Hu
Yongqi Hu over 3 years ago
I am simulating the PLL (accomplished by Verilog A) using PLL+Pnoise, but it failed to converge, and I tried a lot of methods to make it converge, unfortunately, it all failed.
So I want to know if there are any methods to make the PLL converge.
I really hope someone can give me some advice.
Thanks a lot.
    Andrew Beckett over 3 years ago in reply to Yongqi Hu
    Well, that's not going to work (as I said before). The hidden state detection is there for a reason - the only time it's OK to add that attribute is when the hidden state does not affect the model (for example, it's related to printing some information, or it's in a signal source, or in an output measurement block). In this case this impacts the behaviour between input and output of the divider - see Hidden State in SpectreRF
    Given that there may be other issues in your design or other models, please contact customer support (submit a case after logging in) - it's not going to be efficient to keep going back and forth trying to tease out or guess what you have done.
