  2. Mixed-Signal Design
  3. Virtuoso AMS error
  • Replies 7
  • Subscribers 67
  • Views 10748
Virtuoso AMS error
Emily157
Emily157 over 2 years ago
Hi All,
I failed to create cellview but my parser log file is empty.
I am sure that my coding is correct. Because the same coding description with half coding lines can successfully create the cellview.
My coding line is up to 10860, I wonder if that is the reason.
I also got a warning : (SCH-1059): Failed to generate pin list from cellview "xxx". Check there are no syntax errors and try again.
Can you please help me out with this? Thank you.
    Andrew Beckett over 2 years ago +1
    Can you share the Verilog-AMS code? Also, the XCELIUM and IC versions that you are using. Andrew
  • Emily157
    Emily157 over 2 years ago in reply to Andrew Beckett
    XCELIUM version:XCELUM_22.03.003
    IC version: IC_06.18.250
  • Emily157
    Here is my Verilog-AMS code.
    sttmram0_32_16.txt
    Andrew Beckett over 2 years ago in reply to Emily157
    You'll need to contact customer support. It appears that the code compiles OK, but the option used to extract some of the structure information (the xmvlog -zparse option) is failing with an internal error. That needs investigating by R&D. Please log into the support site and then submit a case together with the model code you provided here.
  • Emily157
    OK, thanks.
    Emily,
    As a stop-gap, you can comment out (with /* and */ ) the contents of the module - leave all the I/O definitions. You also need to comment out (with //) the two parameter real array lines (Rap and Rp); these are the two that seem to be causing the problem with the analysis. Save and Extract, and then remove the comments. At least this way you'll end up with the netlist.oa (and will be prompted for symbol creation), and then having removed the comments it would fail to extract, but you'd still have the previous extraction.
    I had initially thought of suggesting you replacing the core of the module with loops with genvars to create the structure, but I think the real issue is the big parameter array.
    For support (your point about support access seems to have been deleted from the thread), if you're an academic institution then you would either go via Europractice support (if in the Europractice scheme) or elsewhere you can get your University liaison (whoever is responsible for the University program at your institution) to create the support case - it's just not open to everyone so that there is some level of filtering within each institution.
  • Emily157
    Copy that, I'll give it another shot with a different approach, thank you very much!
    Best Regards,
    Emily
