  2. Mixed-Signal Design
  3. xmelab: *E,CUVHNF error using Xcelium 19.09-s008
  • Subscribers 67
  • Views 5931
markris
markris over 2 years ago
Hello everyone,
I have the following error starting a simulation with Xcelium 19.09-s008:
xmelab: *E,CUVHNF (netlist.vams,3630|51): Hierarchical name component lookup failed at 'round'.
Looking at the netlist, exactly at the line 3630, I get that a device parameter is using the "round" function that is correctly solved using Spectre stand alone instead:
nmos_test #(.mult(round(20/2-0.5)),
I guess the issue is related to the fact that the netlist in AMS designer is based on VAMS language it supports only "floor" and not "round" as a rounding function (but the rounding behavior will change obviously).
However, is there a way cia e a switch in xrunArgs to solve this issue and get the function solved in Xcelium too without changing the design?
Thanks a lot in advance!
    Hi Marco,
    In fact I wasn't aware that Spectre supported round - I then found that this was added via CCR 1668374 in an MMSIM15.1/SPECTRE16.1 hotfix a number of years back (although I don't think it's documented - it probably should be). I haven't found any reports of the specific issue with AMS Designer (I can reproduce the issue). As you say, round() is not in the Verilog-AMS standard.
    What's odd here is that the subtraction of 0.5 means that round(N-0.5) is the same as doing floor(N) (other than with negative numbers), so maybe the solution is best to change the expression to use floor()?
    Otherwise I think it would need an enhancement for AMS to support this non-standard function. I did consider defining an analog function to implement round, but you can't use an analog function in this context.
  • markris
    markris over 2 years ago in reply to Andrew Beckett
    Yes I can use floor, but the rounding is a bit different because if I round 1.6, for example, with round I would get 2 and with floor I would get 1 (accordingly to round and floor Spectre reference manual definition).
    But ok, at least you confirm my finding. For now, I would say to not improve anything, since it is simply a known VAMS syntax limitation.
    Thanks for confirming it,
    Marco.
    Andrew Beckett over 2 years ago in reply to markris
    Marco,
    I know that round and floor are different. My point was that your example was subtracting 0.5 before doing round; that’s equivalent of doing floor on the expression without the subtraction - ie round(N-0.5) is the same as floor(N). This may or may not help!
  • markris
    Yeah, got it. Ok, I will keep in mind. Thanks for your quick reply as always. Wish you a nice day!
