  2. Mixed-Signal Design
  3. PSS + PNOISE Simulation Problem for the PLL
  • Subscribers 67
  • Views 6754
MtnDew12fl
MtnDew12fl over 2 years ago
Hi all,
My PSS analysis is not converging and giving errors. I have attached the images for settings of my PSS analysis. Cannot figure where I am getting wrong. My beat frequency is 86.25 Mhz and PLL is locking at 690Mhz. It's a basic CP-PLL.
    I'm assuming your reference clock is 86.25MHz and you have a divide-by-8 in the PLL loop? Your VCO output frequency seems to be wandering quite a bit - do you have a dead band in your phase detector?
    It's probably easiest to deal with this through customer support (submit a support case after logging in), to be honest, as seeing your design/setup would make it easier to debug.
  • MtnDew12fl
    MtnDew12fl over 2 years ago in reply to Andrew Beckett
    First Question is Yes. And for second, I think that I do have a dead band problem. Thank You for pointing that out.
