  2. Mixed-Signal Design
  3. [dynamic node capacitance check][couldn't find the check...
  • Subscribers 67
  • Views 2925
[dynamic node capacitance check][couldn't find the check results]
IssacW
IssacW over 2 years ago
dear tutors & peer,
I'm performing a dynamic check on the node capacitance,
though I couldn't find any output info there. there is no
"xxx.dynamic.xml" under simulation directory as well.
may I know how to export the results into either log file or results tabs?
PS. the assert works well instead.
  • IssacW
    Andrew Beckett over 2 years ago in reply to IssacW
    I just tried this and it worked fine for me. Can you share (as there's not a great deal of information above - certainly nothing on the setup or versions used):
    1. What you have on the Checks/Asserts assistant (i.e. how you have set up the check)
    2. What you get - on the results tab (Detail view), use Right Mouse->View Netlisted Checks/Asserts - i.e. what statements were written into the netlist
    3. What the stop time for the transient simulation was
    4. Which Spectre sub-version was used (this will appear near the top of the Spectre simulation log)
    5. Which IC sub-version are you using (Help->About will tell you this)
    6. Do you get anything from Right Mouse->View Dynamic/Static Violation Report (I guess not, since the Checks/Asserts view is missing).
    7. Is there anything in the drop down box next to "Cumulative" in the picture above?
  • IssacW
    IssacW over 2 years ago in reply to Andrew Beckett
    hi Andrew,
    sorry for my late feedback as our env. is in the process of migration these days.
    [1] I've figured out the cause of this problem:
         it is due to the additional "subckt/inst" parameter I add in the "dyn_nodecap" check,
         which as a result will not stop the simulation but just gives nothing.
         anyway I really appreciate your step-by-step instructions above on how to debug this issue.
    [2] now I'm able to see the results under "checks/asserts" tab. but is there any other way to export the results into, say log or excel files?
         I couldn't still find "xxx.dynamic.xxx"......
    [3] on the other hand, it seems like not all the static/dynamic checks are supported in a specific release of spectre, just like what the picture             shows below. is there a way for us to check what kind of dynamic checks are available in our env., like "spectre -h xxxx"?
    PS. I will add the setup/version info next time I post questions. sorry about this I'm still on the way of getting familiar with the way how we work         here.
