  2. Mixed-Signal Design
  3. Why my Verilog‘s digital outputs are correct in Vivado but...
  • Subscribers 67
  • Views 3754
Why my Verilog‘s digital outputs are correct in Vivado but 'x' in Cadence AMS?
Cookies
Cookies over 2 years ago
Here is what it should be:
but this is the same Verilog in AMS, i`m wondering how to make the output right:
This is the tb schematic:
And here`s the Verilog code, it described a state machine:
I can make right with another Verilog code and the same process, so is there something wrong in my code?
Here is the another one, is a logic gate.
    Please post the text of the code rather than just a screenshot. Being able to play around with the example while thinking about it would help, and I'm not going to spend time typing it in from a picture...
  • tpylant
    tpylant over 2 years ago
    How come 'exchange' is toggling so much in the AMS sim vs. the digital sim? In the digital sim there are four toggles of 't' for one toggle of 'exchange'
    Tim
  • Cookies
    Cookies over 2 years ago in reply to Andrew Beckett
    I`m sorry and here is the code.
    module exchange_ctrl(
    input wire exchange,
    input wire [1:0] sort_wordline_x1,
    input wire t,
    output reg [1:0] ex_wl_source,
    output reg [1:0] ex_wl_dest,
    output reg exchange_done
    localparam S0 = 2'b00;
    localparam S1 = 2'b01;
    localparam S2 = 2'b10;
    localparam S3 = 2'b11;
    reg [1:0] state, next_state;
    always @(posedge t) begin
    if (exchange) begin
    state <= next_state;
    end else begin
    state <= S0;
    end
    end
    always @(*) begin
    case (state)
    S0: next_state = S1;
    S1: next_state = S2;
    S2: next_state = S3;
    S3: next_state = S0;
    default: next_state = S0;
    endcase
    end
    if (exchange) begin
    case (state)
    S0: begin
    ex_wl_source <= sort_wordline_x1;
    ex_wl_dest <= 2'b11;
    exchange_done <= 1'b0;
    end
    S1: begin
    ex_wl_source <= sort_wordline_x1 + 2'b01;
    ex_wl_dest <= sort_wordline_x1;
    end
    S2: begin
    ex_wl_source <= 2'b11;
    ex_wl_dest <= sort_wordline_x1 + 2'b01;
    end
    S3: begin
    ex_wl_source <= 2'b00;
    ex_wl_dest <= 2'b00;
    exchange_done <= 1'b1;
    end
    endcase
    end else begin
    end
    end
    initial begin
    state <= S0;
    end
    endmodule
  • Cookies
    Cookies over 2 years ago in reply to tpylant
    Are you talking about the final image?  I am designing a sequencing circuit based on SRAM In-Memory-Computing. And the final image is a simulation of a compare circuit, which is used to compare the data in two selected storage unit(2bit) and signal "exchange".
     The circuits I'm designing are used to verify the correctness of my SRAM, I don't need to think about their performance for now,  as long as they function correctly
