  2. Mixed-Signal Design
  3. Missing pins in symbol creation of systemVerilog module
  • Subscribers 67
  • Views 7641
MostafaAbedi
MostafaAbedi over 2 years ago
Hi everyone,
I am doing AMS simulation and want to create a symbol of a  systemVerilog module. in this systemVerilog module (main.sv) a package is also imported (package.sv) which is already compiled. The issue is that when I want to create a symbol for ‘main.sv’, some pins are not generated as you see in the screenshot, and are noted as ‘NulPort’:
This is a snippet of ‘main.sv’ where these 4 ports are defined:
And these is the snippet of ‘package.sv’ where the type of these ports is defined:
Any idea about how to solve the issue?( to have the 4bit pins  'i_mosi_state_0' and 'i_mosi_state_1' , and the 5bit pins  'i_moji_state_0' and 'i_moji_state_1')
Thanks!
Mostafa
  • MostafaAbedi
    Hi everyone,
    Thanks!
    Mostafa
    Andrew Beckett over 2 years ago in reply to MostafaAbedi
    Mostafa,
    I see the same issue. I found some reported problems with other scenarios which give the same outcome, but these have been fixed. I'm assuming that it's related to the typedef being multi-bit, but I'm not sure. Anyway, I filed a change request #3045801 for this; you probably should contact customer support (submit a case after logging in) and reference this post and request that a duplicate is filed on your behalf.
    Andrew Beckett over 2 years ago in reply to Andrew Beckett
    I found a workaround - this problem only occurs (by default) in IC23.1 (which explains why it may not have been reported before - the issue has only appeared relatively recently). If you set:
    vmsEnableRapidImport = nil
    in the CIW before the symbol is generated, then the pins will be correctly created.
  • MostafaAbedi
    MostafaAbedi over 2 years ago in reply to Andrew Beckett
    Thank you so much. Yes, it is IC23.1, and by setting 'vmsEnableRapidImport = nil' in CIW it created the pins that were missing. It is still not multi-bit though, and I will probably have error if I connect a multi-bit net to a single pin in schematic. Seems I will need to modify the code, or create a wrap code or something.
    Thank you again.
    Mostafa
