  2. Mixed-Signal Design
  3. White phase noise in VCO decays with frequency – not flat...
  • Subscribers 67
  • Views 4342
White phase noise in VCO decays with frequency – not flat as expected
brunoalexandrefraga
brunoalexandrefraga over 1 year ago
Hi everyone,
I’m implementing a simple sinusoidal VCO in Verilog-A for phase noise analysis using PSS+PNOISE. I added white phase noise using only the white_noise function, as shown in the code snippet below. I expect the noise floor to remain flat (constant) at higher frequency offsets, but instead, it decays approximately at 20 dB/dec until it reaches the expected bottom value.
Verilog-A snippet:
`include "disciplines.vams"
`include "constants.vams"
module vco0 ( vctrl, out );
input vctrl; voltage vctrl;
output out; voltage out;
parameter real vmin=0;
parameter real vmax=vmin+1 from (vmin:inf);
parameter real fmin=1 from (0:inf);
parameter real fmax=2*fmin from (fmin:inf);
parameter real bottom = -130;
real wn_level = pow(10, bottom/10);
real freq, phase;
integer n;
real wn;
analog begin
freq = (V(vctrl) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin;
if (freq > fmax) freq = fmax;
if (freq < fmin) freq = fmin;
phase = 2*`M_PI*idtmod(freq, 0, 1, -0.5);
wn = white_noise(wn_level, "vco_white");
V(out) <+ sin(phase + wn);
end
endmodule
I’m attaching a plot from my PNOISE simulation where you can see this behavior. I’ve also included a reference line with a 20 dB/dec slope to highlight that the noise curve follows that same decline before reaching the bottom at -130 dBc/Hz. This seems to contradict the assumption that white phase noise should produce a flat region in the phase noise spectrum.
I also attached the configuration of my PSS and PNOISE simulation, as well as the testbench I'm using to this simulations.
Link for the files (images for configurations and responses): https://drive.google.com/drive/folders/1t1UDG6E_qu5o_2h0W1WK1M_lZ9LUtvHN?usp=sharing
Why is the white phase noise not flat as expected?
Any insights would be greatly appreciated. Thanks in advance!
Best regards,
Bruno.
    See the section (3) on Oscillators in https://designers-guide.org/analysis/PLLnoise.pdf (it has references to other papers, such as that from Demir) which talk about this expected phenomenon. The white noise would result in a 20dB/decade slope at the oscillator frequency followed by a flat noise floor.
