  2. Mixed-Signal Design
  3. Simulation of VerilogA model of a VCO ?
  • Subscribers 67
  • Views 5116
PE202503078250
PE202503078250 over 1 year ago
I'm using a very simple verilogA model of a VCO and running HB as well as PSS simulations, but neither of them converge. However, the transient simulation runs.
Is there some simulation engine specific reason behind this or are there some specific settings to be used ?
    Can you share the model? The common mistake is for the phase not to be periodic, which is solvable using idtmod rather than idt - but seeing the model would really help here.
  • PE202503078250
    PE202503078250 over 1 year ago in reply to Andrew Beckett
    Hi Andrew, thanks for the reply. Below given is the VerilogA model
    module VCO(out_p, out_n, Vtp, Vtn, tail);
    inout out_p, out_n; // Differential outputs
    input Vtp, Vtn; // Differential tuning voltage
    electrical out_p, out_n, Vtp, Vtn, tail;
    // Parameters
    parameter real fvco = 4.5e9; // Center frequency in Hz
    parameter real Kvco = 1.0e6; // VCO gain in Hz/V
    parameter real Vout_CM = 0.8; // Output common-mode voltage (V)
    parameter real Avco = 0.5; // Differential peak amplitude (V)
    // Internal variables
    real freq, phase;
    real Vctrl_diff;
    analog begin
    // Compute differential tuning voltage
    Vctrl_diff = V(Vtp) - V(Vtn);
    // Frequency as function of control voltage
    freq = fvco + Kvco * Vctrl_diff;
    // Integrate frequency to get phase (rad)
    phase = 2 * `M_PI * idt(freq, 0.0);
    // Output differential sine wave
    V(out_p) <+ Vout_CM + Avco * sin(phase);
    V(out_n) <+ Vout_CM - Avco * sin(phase);
    end
    endmodule
    Andrew Beckett over 1 year ago in reply to PE202503078250
    If you change the line:
    to
    phase = 2 * `M_PI * idtmod(freq, 0.0, 1);
    Then it will converge with PSS. The issue with the original was that the phase keeps increasing and so there's no periodic solution.
    The problem, however, is that idtmod is not supported in harmonic balance. Somehow I'd not noticed that - let me do some digging (I found an internal request on this but no clear outcome).
    Andrew Beckett over 1 year ago in reply to Andrew Beckett
    I'd also suggest you add:
    $bound_step(1/freq/20);
    to the model to force a few more time steps per period. The dynamic timestep control tends to need a bit of a clue with oscillator models as other things in the circuit may not be enough to cause the time steps to be small enough to follow the output properly.
